1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Qt edm code
To: "John Sinclair" <[email protected]>
Cc: [email protected]
Date: Tue, 6 Nov 2007 13:09:18 -0800
Thanks John.
Zen
-----Original Message-----
Sent: Tuesday, November 06, 2007 12:39 PM
To: Szalata, Zenon M.
Subject: Re: Qt edm code
Zen,
My mistake. The mysql piece should have been commented out.
So, in makefile.pv, comment out the lines near the end of the file that
read:
FLAGS4 = -g -O0 -I.
libDb.so : db_pv_factory.o regDb.o
        g++ $(LDFLAGS) -shared -Wl \
        -o libDb.so \
        -L ./ \
        -L/usr/lib/mysql \
        -lPvSupport \
        -lmysqlclient_r \
        -lm \
db_pv_factory.o : db_pv_factory.cc
        g++ $(FLAGS4) -o db_pv_factory.o -c db_pv_factory.cc
regDb.o : regDb.cc
        g++ $(FLAGS4) -o regDb.o -c regDb.cc
John Sinclair
Szalata, Zenon M. wrote:
> After a bit of a struggle (in addition to EPICS_TOP, EPICS_HOST_TYPE env also needs to be defined) this is what I get and I do not know where the file mysql.h is supposed to come from:
> g++ -g -O0 -I. -o db_pv_factory.o -c db_pv_factory.cc
> In file included from db_pv_factory.cc:9:
> db_pv_factory.h:11:25: mysql/mysql.h: No such file or directory
> db_pv_factory.cc: In function `int doSelect(char*, char*, char*, char*, int)':
> db_pv_factory.cc:55: error: `MYSQL' was not declared in this scope
> db_pv_factory.cc:55: error: `m' was not declared in this scope
> db_pv_factory.cc:56: error: `MYSQL_RES' was not declared in this scope
> db_pv_factory.cc:56: error: `result' was not declared in this scope
> db_pv_factory.cc:57: error: `MYSQL_ROW' was not declared in this scope
> db_pv_factory.cc:57: error: expected `;' before "row"
> db_pv_factory.cc:58: error: `MYSQL_FIELD' was not declared in this
> scope
> db_pv_factory.cc:58: error: `fields' was not declared in this scope
> I have qt-4.3.2 open source installed.  I find that there is a file:
> Qt-4.3.2/include/QtSql/qsql_mysql.h
> Is this the file that should be include?
> Am I in trouble because I have Qt-4.3.2?
> Thanks,
> Zen
> From: [email protected]
> [mailto:[email protected]] On Behalf Of John Sinclair
> Sent: Tuesday, November 06, 2007 7:18 AM
> To: [email protected]
> Subject: Qt edm code
> All,
> Qt edm pre-alpha code is now available at
> http://ics-web1.sns.ornl.gov/edm/info/show.php?mon=Nov&theDay=6&year=2
> 007
> John Sinclair
Qt edm code John Sinclair
RE: Qt edm code Szalata, Zenon M.
Re: Qt edm code John Sinclair
Prev: Re: Qt edm code John Sinclair
Next: RE: Stream device Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS IOC startup scripts... Ralph Lange
