1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS IOC startup scripts...
To: Dave Reid <[email protected]>
Date: Tue, 06 Nov 2007 17:05:50 +0100
Hi -
(putting this on tech-talk instead of CCing a dozen people since it might be of interest to a broader audience)
the Screen utility is what the original APS iocConsole (and SLAC's version of it) is based on, and it's what BESSY is using so far.
IocConsole uses Screen's ability to allow multiple users parallel access to the soft IOC console as well as Screen's logging mechanism.
BESSY has put Screen as the "soft IOC container" below Conserver, a free client/server software that manages logging and parallel access (including authorization and authentication) to all serial type connections, thereby unifying the access to all IOCs, soft and VME based.
Therefore, we do not use the parallel access and logging mechanisms of Screen: Only one client (the Conserver) is logged into the Screen session running the IOC all the time. (I put a wiki page on the EPICS web about this.)
Stephanie Allison (SLAC) has seen softIOCs hang when people use the history scrolling mechanism of Screen.
We found that Screen puts ugly vt100 control characters into Conserver's log files.
The SNS is using a small wrapper (called procServ) around their soft IOCs that provides telnet access to stdin and stdout of the IOC as well as file logging. It also restarts the softIOC when it terminates to allow rebooting softIOCs, and writes a PID file. Blowing this up to allow parallel access to the console is still on their to-do-list.
To me, the best solution at the moment sounds like running the soft IOC under procServ (just as a minimal IOC shell) and Conserver on top (to provide shared access, logging, integration of VME and soft IOCs).
To forward the log content to Conserver, I'm right now trying to have procServ log into a named pipe, so that Conserver - when it reconnects - still gets the complete history of a rebooting soft IOC. (Conserver will telnet to the procServ port for access and ssh to cat the named pipe for logging.)
I will also try to allow a certain exit code from the IOC keeping procServ from restarting the IOC, so that orderly shutdown and reboot will be available from the iocsh.
Corrections, encouragement, ideas anyone?
Stay tuned ....
Ralph
Dave Reid wrote:
Heinrich, Ralph--
I was digging around on Tech-Talk looking for some information about starting up soft IOC's using scripts, and saw your notes about using the SCREEN utility.
We are trying to use that here, but we've run into somewhat of an interesting issue. I was looking at a running IOC this morning, and when I tried to "detach", using the CTL+A+D, for some reason the "A" part didn't take, and I ended up crashing the IOC. Obviously, this doesn't go over very well.
Is using the SCREEN utility still the only way to do something like this? Have you ever run into a problem like this with inadvertently crashing an IOC?
Thanks for any input...
Dave Reid
University of Washington Medical Center
Prev: Re: EPICS on Mac OS X 10.5 Andrew Johnson
Next: RE: question about iocConsole Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Qt edm code Szalata, Zenon M.
Next: problem in running application of gpib-device zhangdemin99
