1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stream device
To: "Szalata, Zenon M." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 07 Nov 2007 13:50:08 +0100
Hello Zenon,
please try the attached version of AsynDriverInterface.cc with StreamDevice version 2.3.
I changed the location of the asynCommon->connect call. For me, that helped.
Dirk
Szalata, Zenon M. wrote:
Hi Mark, Dirk,
I built my test application (btest) against SLAC/LCLS EPICS R3.14.8.2, asyn 4.7, and streamdevice 2.2. Still get the following even with asynSetTraceMask( "L0",8,0):
#!../../bin/linux-x86/atest
< envPaths
epicsEnvSet(ARCH,"linux-x86")
epicsEnvSet(IOC,"iocbtest")
epicsEnvSet(TOP,"/afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/btest")
epicsEnvSet(EPICS_SITE_TOP,"/nfs/slac/g/lcls/build/epics")
epicsEnvSet(ASYN,"/nfs/slac/g/lcls/build/epics/modules/asyn/asyn-R4-7-1-lcls2")
epicsEnvSet(STRM,"/nfs/slac/g/lcls/build/epics/modules/streamdevice/streamdevice
-R2-2-lcls2")
epicsEnvSet(EPICS_BASE,"/nfs/slac/g/lcls/build/epics/base/base-R3-14-8-2-lcls2")
epicsEnvSet( "STREAM_PROTOCOL_PATH","../../btestApp/Db:.")
cd /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/btest
dbLoadDatabase("dbd/btest.dbd",0,0)
btest_registerRecordDeviceDriver(pdbbase)
vxi11Configure( "L0","134.79.64.25",0,0.0,"gpib0",0,0)
#asynSetTraceMask( "L0",0,255)
dbLoadRecords("db/btest.db","P=AG:,L=0,A=8")
cd /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/btest/iocBoot/iocbtest
iocInit()
Starting iocInit
###  EPICS IOC CORE built on Oct 30 2007
###  EPICS R3.14.8.2-LCLS_2 $R3-14-8-2$ $2006/01/06 15:55:13$
2007/11/06 20:06:48.372 AG:WFreq: asynError in write: L0 port is not connected
2007/11/06 20:06:48.372 AG:WFreq: @init handler failed
2007/11/06 20:06:48.372 AG:WFreq: Record initialization failed
Bad init_rec return value PV: AG:WFreq ao: init_record
iocInit: All initialization complete
epics> exit
zms@esaux1 $
So, it is not my installation of these three software packages. What is it? I also ran btest with the asynSetTraceMask commented out and got exactly the same errors.
Any help is greatly appreciated. Thanks,
Zen
-----Original Message-----
From: Mark Rivers [mailto:[email protected]] Sent: Monday, November 05, 2007 10:38 AM
To: Szalata, Zenon M.; Dirk Zimoch
Cc: EPICS tech-talk
Subject: RE: Stream device
Dirk wrote:
I tried to do some debugging with the asynTrace facility and found
that the problem
disappears as soon as I call asynSetTraceMask, even with a 0 mask!
That is because the asynSetTraceMask causes a call to
asynCommon->connect. I had suggested this earlier to Zen. However, I
see that you used an asyn "address" of 8, while I was suggesting 0.
Zen, are you sure you tried adding the asynSetTraceMask with the subaddress that your @init device is actually using?
[mailto:[email protected]] On Behalf Of Szalata, Zenon M.
Sent: Monday, November 05, 2007 12:11 PM
To: Dirk Zimoch
Cc: EPICS tech-talk
Hi Dirk,
Unfortunately this does not solve my problem. I am using epics R3.14.9 and asyn 4-9. This is the output I get with my simple test soft IOC:
zms@esaux1 $ ../../bin/linux-x86/atest st.cmd #!../../bin/linux-x86/atest < envPaths
epicsEnvSet(IOC,"iocagwfg")
epicsEnvSet(TOP,"/afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest")
epicsEnvSet(ASYN,"/afs/slac/g/esa/ilc/epics/modules/asyn/4-9")
epicsEnvSet(STRM,"/afs/slac/g/esa/ilc/epics/modules/streamdevice-2-3")
epicsEnvSet(EPICS_BASE,"/afs/slac/g/esa/ilc/epics/base/R3-14-9-ilc1")
epicsEnvSet( "STREAM_PROTOCOL_PATH","../../atestApp/Db:.")
cd /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest
dbLoadDatabase("dbd/atest.dbd",0,0)
atest_registerRecordDeviceDriver(pdbbase)
dbLoadRecords("db/atest.db","P=AG:")
cd
/afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest/iocBoot/iocagwfg
iocInit()
Starting iocInit
## EPICS R3.14.9-lcls1 $R3-14-9$ $2007/02/05 16:31:45$ ## EPICS Base built Oct 2 2007 ##############################################################
2007/11/05 09:51:13.140 AG:WFreq: asynError in write: L0 port is not connected
2007/11/05 09:51:13.141 AG:WFreq: @init handler failed
2007/11/05 09:51:13.141 AG:WFreq: Record initialization failed Bad init_rec return value PV: AG:WFreq ao: init_record
epics> 2007/11/05 09:51:23.143 AG:RFreq: asynError in write: L0 port is not conn
ected
exit
zms@esaux1 $
Here are my atest.db and atest.proto files:
record( ai,"$(P)RFreq"){
  field( DESC, "read frequency")
  field( DTYP, "stream")
  field( SCAN, "10 second")
  field( PREC, "2")
  field( EGU,  "Hz")
  field( INP,  "@atest.proto rFreq L0 8") } record( ao,"$(P)WFreq"){
  field( DESC, "write frequency")
  field( SCAN, "Passive")
  field( PREC, "2")
  field( EGU,  "Hz")
  field( OUT,  "@atest.proto wFreq L0 8") }
# file: atest.proto
Terminator=LF;
rFreq{ out "FREQ?"; in "%f";}
wFreq{ out "FREQ %f"; @init{ rFreq;}}
Here is the tail end of constructed atest.dbd file:
device(waveform,INST_IO,asynFloat64ArrayWfOut,"asynFloat64ArrayOut")
device(asyn,INST_IO,asynRecordDevice,"asynRecordDevice")
driver(stream)
driver(drvAsyn)
registrar(asSub)
registrar(streamRegistrar)
registrar(asynRegister)
registrar(asynInterposeFlushRegister)
registrar(asynInterposeEosRegister)
registrar(vxi11RegisterCommands)
registrar(drvAsynIPPortRegisterCommands)
registrar(drvAsynSerialPortRegisterCommands)
variable(asCaDebug,int)
variable(dbRecordsOnceOnly,int)
variable(dbBptNotMonotonic,int)
variable(streamDebug,int)
And finally, her is atestApp/src/Makefile:
TOP=../..
include $(TOP)/configure/CONFIG
PROD_IOC = atest
DBD += atest.dbd
atest_DBD += base.dbd
atest_DBD += stream.dbd
atest_DBD += asyn.dbd
atest_DBD += drvVxi11.dbd
atest_DBD += atestSup.dbd
# <name>_registerRecordDeviceDriver.cpp will be created from <name>.dbd atest_SRCS += atest_registerRecordDeviceDriver.cpp
atest_SRCS_DEFAULT += atestMain.cpp
atest_SRCS_vxWorks += -nil-
#The following adds support from base/src/vxWorks atest_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
#add a definition for each support application used by this application atest_LIBS += stream atest_LIBS += asyn
atest_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
Are you using earlier versions of Epics or asyn? If you are using the same version of these two packages, am I missing something in my Makefile or some other files?
Thanks for helping,
Zen
Sent: Monday, November 05, 2007 5:59 AM
Hello Zen,
I tested @init handlers with several devices today. I found that TCP ports as well as serial ports work as expected. The problem only occurs with vxi11 ports.
However, I got different error messages:
2007/11/05 13:57:32.057 gpib0,8 vxiCreateDeviceLink RPC error
: RPC: Timed out
2007/11/05 13:57:32.058 L0 vxiCreateDevLink failed for addr 8
2007/11/05 13:57:32.058 asynManager::asynConnectCallback, port L0 error calling
asynCommon->connect
2007/11/05 13:57:36.067 L0 vxi11 clientCall errno 0 clnt_stat
5 L0 vxiBusStatus RPC error : RPC: Timed out
2007/11/05 13:57:36.067 L0 asynGpib:srqPoll srqStatus error timeout
2007/11/05 13:57:40.077 L0 vxi11 clientIoCall errno 0 clnt_stat 5
2007/11/05 13:57:40.077 DZ:cmd: asynError in write: L0 RPC failed
2007/11/05 13:57:40.078 DZ:cmd: @init handler failed
2007/11/05 13:57:40.078 DZ:cmd: Record initialization failed
StreamDevice error messages start with "asynError in write: L0 RPC failed". All above is drvVxi11 or asynManager.
I tried to do some debugging with the asynTrace facility and found that the problem disappears as soon as I call asynSetTraceMask, even with a 0 mask!
Thus try this in your startup script:
asynSetTraceMask ("L0",8,0)
However, I still have not the slightest idea what goes wrong in the vxi11 driver.
I Hope this helps.
Dirk
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
* StreamDevice Support                                         *
* (C) 2005 Dirk Zimoch ([email protected])                    *
* This is the interface to asyn driver for StreamDevice.       *
* Please refer to the HTML files in ../doc/ for a detailed     *
* documentation.                                               *
* If you do any changes in this file, you are not allowed to   *
* redistribute it any more. If there is a bug or a missing     *
* feature, send me an email and/or your patch. If I accept     *
* your changes, they will go to the next release.              *
* DISCLAIMER: If this software breaks something or harms       *
* someone, it's your problem.                                  *
#include "devStream.h"
#include "StreamBusInterface.h"
#include "StreamError.h"
#include "StreamBuffer.h"
#ifdef EPICS_3_14
#include <epicsAssert.h>
#include <epicsTime.h>
#include <epicsTimer.h>
#else
#include <assert.h>
#include <wdLib.h>
#include <sysLib.h>
extern "C" {
#include <callback.h>
#endif
#include <asynDriver.h>
#include <asynOctet.h>
#include <asynInt32.h>
#include <asynUInt32Digital.h>
#include <asynGpibDriver.h>
/* How things are implemented:
synchonous io:
lockRequest()
    pasynManager->blockProcessCallback(),
    pasynCommon->connect() only if
        lockTimeout is unlimited (0) and port is not yet connected
    pasynManager->queueRequest()
    when request is handled
        lockCallback(StreamIoSuccess)
    if request fails
        lockCallback(StreamIoTimeout)
writeRequest()
        pasynOctet->flush()
        pasynOctet->writeRaw()
        if writeRaw() times out
            writeCallback(StreamIoTimeout)
        if writeRaw fails otherwise
            writeCallback(StreamIoFault)
        if writeRaw succeeds and all bytes have been written
            writeCallback(StreamIoSuccess)
        if not all bytes can be written
            pasynManager->queueRequest() to write next part
    if request fails
readRequest()
        optionally: pasynOctet->setInputEos()
        pasynOctet->read()
        if time out at the first byte
            readCallback(StreamIoNoReply)
        if time out at next bytes
            readCallback(StreamIoTimeout,buffer,received)
        if other fault
            readCallback(StreamIoFault,buffer,received)
        if success and reason is ASYN_EOM_END or ASYN_EOM_EOS
            readCallback(StreamIoEnd,buffer,received)
        if success and no end detected
            readCallback(StreamIoSuccess,buffer,received)
        if readCallback() has returned true (wants more input)
            loop back to the pasynOctet->read() call
    if request fails
        readCallback(StreamIoFault)
unlock()
    call pasynManager->unblockProcessCallback()
asynchonous input support ("I/O Intr"):
pasynOctet->registerInterruptUser(...,intrCallbackOctet,...) is called
initially. This calls intrCallbackOctet() every time input is received,
but only if someone else is doing a read. Thus, if nobody reads
something, arrange for periodical read polls.
extern "C" {
static void handleRequest(asynUser*);
static void handleTimeout(asynUser*);
static void intrCallbackOctet(void* pvt, asynUser *pasynUser,
    char *data, size_t numchars, int eomReason);
static void intrCallbackInt32(void* pvt, asynUser *pasynUser,
    epicsInt32 data);
static void intrCallbackUInt32(void* pvt, asynUser *pasynUser,
    epicsUInt32 data);
enum IoAction {
    None, Lock, Write, Read, AsyncRead, AsyncReadMore,
    ReceiveEvent, Connect, Disconnect
static const char* ioActionStr[] = {
    "None", "Lock", "Write", "Read",
    "AsyncRead", "AsyncReadMore",
    "ReceiveEvent", "Connect", "Disconnect"
static const char* asynStatusStr[] = {
    "asynSuccess", "asynTimeout", "asynOverflow", "asynError"
static const char* eomReasonStr[] = {
    "NONE", "CNT", "EOS", "CNT+EOS", "END", "CNT+END", "EOS+END", "CNT+EOS+END"
class AsynDriverInterface : StreamBusInterface
#ifdef EPICS_3_14
 , epicsTimerNotify
#endif
    asynUser* pasynUser;
    asynCommon* pasynCommon;
    void* pvtCommon;
    asynOctet* pasynOctet;
    void* pvtOctet;
    void* intrPvtOctet;
    asynInt32* pasynInt32;
    void* pvtInt32;
    void* intrPvtInt32;
    asynUInt32Digital* pasynUInt32;
    void* pvtUInt32;
    void* intrPvtUInt32;
    asynGpib* pasynGpib;
    void* pvtGpib;
    IoAction ioAction;
    double lockTimeout;
    double writeTimeout;
    double readTimeout;
    double replyTimeout;
    long expectedLength;
    unsigned long eventMask;
    unsigned long receivedEvent;
    StreamBuffer inputBuffer;
    const char* outputBuffer;
    size_t outputSize;
    int peeksize;
#ifdef EPICS_3_14
    epicsTimerQueueActive* timerQueue;
    epicsTimer* timer;
#else
    WDOG_ID timer;
    CALLBACK timeoutCallback;
#endif
    AsynDriverInterface(Client* client);
    ~AsynDriverInterface();
    // StreamBusInterface methods
    bool lockRequest(unsigned long lockTimeout_ms);
    bool unlock();
    bool writeRequest(const void* output, size_t size,
        unsigned long writeTimeout_ms);
    bool readRequest(unsigned long replyTimeout_ms,
        unsigned long readTimeout_ms, long expectedLength, bool async);
    bool acceptEvent(unsigned long mask, unsigned long replytimeout_ms);
    bool supportsEvent();
    bool supportsAsyncRead();
    bool connectRequest(unsigned long connecttimeout_ms);
    bool disconnectRequest();
    void finish();
#ifdef EPICS_3_14
    // epicsTimerNotify methods
    epicsTimerNotify::expireStatus expire(const epicsTime &);
#else
    static void expire(CALLBACK *pcallback);
#endif
    // local methods
    void timerExpired();
    bool connectToBus(const char* busname, int addr);
    void lockHandler();
    void writeHandler();
    void readHandler();
    void connectHandler();
    void disconnectHandler();
    bool connectToAsynPort();
    void asynReadHandler(const char *data, int numchars, int eomReason);
    asynQueuePriority priority() {
        return static_cast<asynQueuePriority>
            (StreamBusInterface::priority());
    void startTimer(double timeout) {
#ifdef EPICS_3_14
        timer->start(*this, timeout);
#else
        callbackSetPriority(priority(), &timeoutCallback);
        wdStart(timer, (int)((timeout+1)*sysClkRateGet())-1,
            reinterpret_cast<FUNCPTR>(callbackRequest),
            reinterpret_cast<int>(&timeoutCallback));
#endif
    void cancelTimer() {
#ifdef EPICS_3_14
        timer->cancel();
#else
        wdCancel(timer);
#endif
    // asynUser callback functions
    friend void handleRequest(asynUser*);
    friend void handleTimeout(asynUser*);
    friend void intrCallbackOctet(void* pvt, asynUser *pasynUser,
    friend void intrCallbackInt32(void* pvt, asynUser *pasynUser,
        epicsInt32 data);
    friend void intrCallbackUInt32(void* pvt, asynUser *pasynUser,
        epicsUInt32 data);
public:
    // static creator method
    static StreamBusInterface* getBusInterface(Client* client,
        const char* busname, int addr, const char* param);
RegisterStreamBusInterface(AsynDriverInterface);
AsynDriverInterface::
AsynDriverInterface(Client* client) : StreamBusInterface(client)
    pasynCommon = NULL;
    pasynOctet = NULL;
    intrPvtOctet = NULL;
    pasynInt32 = NULL;
    intrPvtInt32 = NULL;
    pasynUInt32 = NULL;
    intrPvtUInt32 = NULL;
    pasynGpib = NULL;
    eventMask = 0;
    receivedEvent = 0;
    peeksize = 1;
    pasynUser = pasynManager->createAsynUser(handleRequest,
        handleTimeout);
    assert(pasynUser);
    pasynUser->userPvt = this;
#ifdef EPICS_3_14
    timerQueue = &epicsTimerQueueActive::allocate(true);
    assert(timerQueue);
    timer = &timerQueue->createTimer();
    assert(timer);
#else
    timer = wdCreate();
    callbackSetCallback(expire, &timeoutCallback);
    callbackSetUser(this, &timeoutCallback);
#endif
    cancelTimer();
    if (intrPvtInt32)
        // Int32 event interface is connected
        pasynInt32->cancelInterruptUser(pvtInt32,
            pasynUser, intrPvtInt32);
    if (intrPvtUInt32)
        // UInt32 event interface is connected
        pasynUInt32->cancelInterruptUser(pvtUInt32,
            pasynUser, intrPvtUInt32);
    if (pasynOctet)
        // octet stream interface is connected
        int wasQueued;
        if (intrPvtOctet)
            pasynOctet->cancelInterruptUser(pvtOctet,
                pasynUser, intrPvtOctet);
        pasynManager->cancelRequest(pasynUser, &wasQueued);
        // does not return until running handler has finished
    // Now, no handler is running any more and none will start.
#ifdef EPICS_3_14
    timer->destroy();
    timerQueue->release();
#else
    wdDelete(timer);
#endif
    pasynManager->disconnect(pasynUser);
    pasynManager->freeAsynUser(pasynUser);
    pasynUser = NULL;
// interface function getBusInterface():
// do we have this bus/addr ?
StreamBusInterface* AsynDriverInterface::
    const char* busname, int addr, const char*)
    AsynDriverInterface* interface = new AsynDriverInterface(client);
    if (interface->connectToBus(busname, addr))
        debug ("AsynDriverInterface::getBusInterface(%s, %d): "
            "new Interface allocated\n",
            busname, addr);
        return interface;
    delete interface;
    return NULL;
// interface function supportsEvent():
// can we handle the StreamDevice command 'event'?
bool AsynDriverInterface::
supportsEvent()
    return (pasynInt32 != NULL) || (pasynUInt32 != NULL);
supportsAsyncRead()
    if (intrPvtOctet) return true;
    // hook "I/O Intr" support
    if (pasynOctet->registerInterruptUser(pvtOctet, pasynUser,
        intrCallbackOctet, this, &intrPvtOctet) != asynSuccess)
        error("%s: bus does not support asynchronous input: %s\n",
            clientName(), pasynUser->errorMessage);
        return false;
    return true;
    if (pasynManager->connectDevice(pasynUser, busname, addr) !=
        asynSuccess)
        // asynDriver does not know this busname/address
        return false;
    asynInterface* pasynInterface;
    // find the asynCommon interface
    pasynInterface = pasynManager->findInterface(pasynUser,
        asynCommonType, true);
    if(!pasynInterface)
        error("%s: bus %s does not support asynCommon interface\n",
            clientName(), busname);
        return false;
    pasynCommon = static_cast<asynCommon*>(pasynInterface->pinterface);
    pvtCommon = pasynInterface->drvPvt;
    // find the asynOctet interface
        asynOctetType, true);
    if(!pasynInterface)
        error("%s: bus %s does not support asynOctet interface\n",
        return false;
    pasynOctet = static_cast<asynOctet*>(pasynInterface->pinterface);
    pvtOctet = pasynInterface->drvPvt;
    // is it a GPIB interface ?
        asynGpibType, true);
    if(pasynInterface)
        pasynGpib = static_cast<asynGpib*>(pasynInterface->pinterface);
        pvtGpib = pasynInterface->drvPvt;
        // asynGpib returns overflow error if we try to peek
        // (read only one byte first).
        peeksize = inputBuffer.capacity();
    // look for interfaces for events
        asynInt32Type, true);
    if(pasynInterface)
        pasynInt32 = static_cast<asynInt32*>(pasynInterface->pinterface);
        pvtInt32 = pasynInterface->drvPvt;
        pasynUser->reason = ASYN_REASON_SIGNAL; // required for GPIB
        if (pasynInt32->registerInterruptUser(pvtInt32, pasynUser,
            intrCallbackInt32, this, &intrPvtInt32) == asynSuccess)
            return true;
        error("%s: bus %s does not allow to register for "
            "Int32 interrupts: %s\n",
            clientName(), busname, pasynUser->errorMessage);
        pasynInt32 = NULL;
    // no asynInt32 available, thus try asynUInt32
        asynUInt32DigitalType, true);
    if(pasynInterface)
        pasynUInt32 =
            static_cast<asynUInt32Digital*>(pasynInterface->pinterface);
        pvtUInt32 = pasynInterface->drvPvt;
        if (pasynUInt32->registerInterruptUser(pvtUInt32,
            pasynUser, intrCallbackUInt32, this, 0xFFFFFFFF,
            &intrPvtUInt32) == asynSuccess)
            return true;
            "UInt32 interrupts: %s\n",
        pasynUInt32 = NULL;
    // no event interface available, never mind
    return true;
// interface function: we want exclusive access to the device
// lockTimeout_ms=0 means "block here" (used in @init)
    debug("AsynDriverInterface::lockRequest(%s, %ld msec)\n",
        clientName(), lockTimeout_ms);
    asynStatus status;
    lockTimeout = lockTimeout_ms ? lockTimeout_ms*0.001 : -1.0;
    ioAction = Lock;
    status = pasynManager->queueRequest(pasynUser, priority(),
        lockTimeout);
    if (status != asynSuccess)
        error("%s lockRequest: pasynManager->queueRequest() failed: %s\n",
        return false;
    // continues with:
    //    handleRequest() -> lockHandler() -> lockCallback()
    // or handleTimeout() -> lockCallback(StreamIoTimeout)
    return true;
connectToAsynPort()
    asynStatus status;
    int connected;
    debug("AsynDriverInterface::connectToAsynPort(%s)\n",
        clientName());
    status = pasynManager->isConnected(pasynUser, &connected);
        error("%s: pasynManager->isConnected() failed: %s\n",
        return false;
    debug("AsynDriverInterface::connectToAsynPort(%s) is %s connected\n",
        clientName(), connected ? "already" : "not yet");
    if (!connected)
        status = pasynCommon->connect(pvtCommon, pasynUser);
        debug("AsynDriverInterface::connectToAsynPort(%s): "
                "status=%s\n",
            clientName(), asynStatusStr[status]);
            error("%s: pasynCommon->connect() failed: %s\n",
            return false;
    return true;
// now, we can have exclusive access (called by asynManager)
void AsynDriverInterface::
lockHandler()
    debug("AsynDriverInterface::lockHandler(%s)\n",
        clientName());
    pasynManager->blockProcessCallback(pasynUser, false);
    lockCallback(connectToAsynPort() ? StreamIoSuccess : StreamIoFault);
// interface function: we don't need exclusive access any more
unlock()
    debug("AsynDriverInterface::unlock(%s)\n",
        clientName());
    pasynManager->unblockProcessCallback(pasynUser, false);
    return true;
// interface function: we want to write something
#ifndef NO_TEMPORARY
    debug("AsynDriverInterface::writeRequest(%s, \"%s\", %ld msec)\n",
        clientName(), StreamBuffer(output, size).expand()(),
        writeTimeout_ms);
#endif
    asynStatus status;
    outputBuffer = (char*)output;
    outputSize = size;
    writeTimeout = writeTimeout_ms*0.001;
    ioAction = Write;
        writeTimeout);
        error("%s writeRequest: pasynManager->queueRequest() failed: %s\n",
        return false;
    // continues with:
    //    handleRequest() -> writeHandler() -> lockCallback()
    // or handleTimeout() -> writeCallback(StreamIoTimeout)
    return true;
// now, we can write (called by asynManager)
writeHandler()
    debug("AsynDriverInterface::writeHandler(%s)\n",
        clientName());
    asynStatus status;
    size_t written = 0;
    pasynUser->timeout = writeTimeout;
    // discard any early input or early events
    status = pasynOctet->flush(pvtOctet, pasynUser);
    receivedEvent = 0;
        error("%s: pasynOctet->flush() failed: %s\n",
        writeCallback(StreamIoFault);
        return;
    // has stream already added a terminator or should
    // asyn do so?
    size_t streameoslen;
    const char* streameos = getOutTerminator(streameoslen);
    if (streameos) // stream has added eos
        status = pasynOctet->writeRaw(pvtOctet, pasynUser,
            outputBuffer, outputSize, &written);
    else // asyn should add eos
        status = pasynOctet->write(pvtOctet, pasynUser,
    switch (status)
        case asynSuccess:
            outputBuffer += written;
            outputSize -= written;
            if (outputSize > 0)
                    priority(), lockTimeout);
                    error("%s writeHandler: "
                        "pasynManager->queueRequest() failed: %s\n",
                // continues with:
                //    handleRequest() -> writeHandler() -> writeCallback()
                return;
            writeCallback(StreamIoSuccess);
            return;
        case asynTimeout:
            writeCallback(StreamIoTimeout);
            return;
        case asynOverflow:
            error("%s: asynOverflow in write: %s\n",
            return;
        case asynError:
            error("%s: asynError in write: %s\n",
            return;
// interface function: we want to read something
readRequest(unsigned long replyTimeout_ms, unsigned long readTimeout_ms,
    long _expectedLength, bool async)
    debug("AsynDriverInterface::readRequest(%s, %ld msec reply, "
        "%ld msec read, expect %ld bytes, asyn=%s)\n",
        clientName(), replyTimeout_ms, readTimeout_ms,
        _expectedLength, async?"yes":"no");
    asynStatus status;
    readTimeout = readTimeout_ms*0.001;
    replyTimeout = replyTimeout_ms*0.001;
    double queueTimeout;
    expectedLength = _expectedLength;
    if (async)
        ioAction = AsyncRead;
        queueTimeout = -1.0;
        // First poll for input (no timeout),
        // later poll periodically if no other input arrives
        // from intrCallbackOctet()
    else {
        ioAction = Read;
        queueTimeout = replyTimeout;
        priority(), queueTimeout);
    if (status != asynSuccess && !async)
        error("%s readRequest: pasynManager->queueRequest() failed: %s\n",
        return false;
    // continues with:
    //    handleRequest() -> readHandler() -> readCallback()
    // or handleTimeout() -> readCallback(StreamIoTimeout)
    return true;
// now, we can read (called by asynManager)
readHandler()
    size_t streameoslen, deveoslen;
    const char* streameos;
    const char* deveos;
    int oldeoslen = -1;
    char oldeos[16];
    // Setup eos if required.
    streameos = getInTerminator(streameoslen);
    deveos = streameos;
    deveoslen = streameoslen;
    if (streameos) do // streameos == NULL means: don't change eos
        asynStatus status;
        status = pasynOctet->getInputEos(pvtOctet,
            pasynUser, oldeos, sizeof(oldeos)-1, &oldeoslen);
            oldeoslen = -1;
            // No EOS support?
        // device (e.g. GPIB) might not accept full eos length
        if (pasynOctet->setInputEos(pvtOctet, pasynUser,
            deveos, deveoslen) == asynSuccess)
            if (ioAction != AsyncRead)
                debug("AsynDriverInterface::readHandler(%s) "
                    "input EOS set to %s\n",
                    clientName(),
                    StreamBuffer(deveos, deveoslen).expand()());
#endif
            break;
        deveos++; deveoslen--;
        if (!deveoslen)
            error("%s: warning: pasynOctet->setInputEos() failed: %s\n",
    } while (deveoslen);
    int bytesToRead = peeksize;
    long buffersize;
    if (expectedLength > 0)
        buffersize = expectedLength;
        if (peeksize > 1)
            /* we can't peek, try to read whole message */
            bytesToRead = expectedLength;
    else
        buffersize = inputBuffer.capacity();
    char* buffer = inputBuffer.clear().reserve(buffersize);
    if (ioAction == AsyncRead)
        // In AsyncRead mode just poll
        // and read as much as possible
        pasynUser->timeout = readTimeout;
        bytesToRead = buffersize;
    else
        pasynUser->timeout = replyTimeout;
    bool waitForReply = true;
    int received;
    int eomReason;
    asynStatus status;
    long readMore;
    while (1)
        readMore = 0;
        received = 0;
        eomReason = 0;
        status = pasynOctet->read(pvtOctet, pasynUser,
            buffer, bytesToRead, (size_t*)&received, &eomReason);
        if (ioAction != AsyncRead || status != asynTimeout)
            debug("AsynDriverInterface::readHandler(%s): "
                "read(..., bytesToRead=%d, ...) [timeout=%f seconds] = %s\n",
                clientName(), bytesToRead, pasynUser->timeout,
        // pasynOctet->read() has already cut off terminator.
        switch (status)
            case asynSuccess:
                        "AsyncRead poll: received %d of %d bytes \"%s\" "
                        "eomReason=%s [data ignored]\n",
                        clientName(), received, bytesToRead,
                        StreamBuffer(buffer, received).expand()(),
                        eomReasonStr[eomReason&0x7]);
#endif
                    // ignore what we got from here.
                    // input was already handeled by asynReadHandler()
                    // read until no more input is available
                    readMore = -1;
                    break;
                        "received %d of %d bytes \"%s\" "
                        "eomReason=%s\n",
#endif
                // asynOctet->read() cuts off terminator, but:
                // If stream has set a terminator which is longer
                // than what the device (e.g. GPIB) can handle,
                // only the last part is cut. If that part matches
                // but the whole terminator does not, it is falsely cut.
                // So what to do?
                // Restore complete terminator and leave it to StreamCore to
                // find out if this was really the end of the input.
                // Warning: received can be < 0 if message was read in parts
                // and a multi-byte terminator was partially read with last
                // call.
                if (deveoslen < streameoslen && (eomReason & ASYN_EOM_EOS))
                    size_t i;
                    for (i = 0; i < deveoslen; i++, received++)
                        if (received >= 0) buffer[received] = deveos[i];
                        // It is safe to add to buffer here, because
                        // the terminator was already there before
                        // asynOctet->read() had cut it.
                        // Just take care of received < 0
                    eomReason &= ~ASYN_EOM_EOS;
                readMore = readCallback(
                    eomReason & (ASYN_EOM_END|ASYN_EOM_EOS) ?
                    StreamIoEnd : StreamIoSuccess,
                    buffer, received);
                break;
            case asynTimeout:
                if (received == 0 && waitForReply)
                    // reply timeout
                        // start next poll after timer expires
                        if (replyTimeout != 0.0) startTimer(replyTimeout);
                        // continues with:
                        //    timerExpired() -> queueRequest() -> handleRequest() -> readHandler()
                        // or intrCallbackOctet() -> asynReadHandler()
                        break;
                        "no reply\n",
                        clientName());
                    readMore = readCallback(StreamIoNoReply);
                    break;
                // read timeout
                        "ioAction=%s, timeout after %d of %d bytes \"%s\"\n",
                    clientName(), ioActionStr[ioAction],
                    StreamBuffer(buffer, received).expand()());
#endif
                if (ioAction == AsyncRead || ioAction == AsyncReadMore)
                    // we already got the data from asynReadHandler()
                    readCallback(StreamIoTimeout, NULL, 0);
                    break;
                readMore = readCallback(StreamIoTimeout, buffer, received);
                break;
            case asynOverflow:
                if (bytesToRead == 1)
                    // device does not support peeking
                    // try to read whole message next time
                    inputBuffer.clear().reserve(100);
                } else {
                    // buffer was still too small
                    // try larger buffer next time
                    inputBuffer.clear().reserve(inputBuffer.capacity()*2);
                // deliver whatever we could save
                error("%s: asynOverflow in read: %s\n",
                readCallback(StreamIoFault, buffer, received);
                break;
            case asynError:
                error("%s: asynError in read: %s\n",
                break;
        if (!readMore) break;
        if (readMore > 0)
            bytesToRead = readMore;
        else
            bytesToRead = inputBuffer.capacity();
            "readMore=%ld bytesToRead=%d\n",
            clientName(), readMore, bytesToRead);
        waitForReply = false;
    // restore original EOS
    if (oldeoslen >= 0)
            oldeos, oldeoslen);
void intrCallbackOctet(void* /*pvt*/, asynUser *pasynUser,
        static_cast<AsynDriverInterface*>(pasynUser->userPvt);
// Problems here:
// 1. We get this message too when we are the poller.
//    Thus we have to ignore what we got from polling.
// 2. We get this message multiple times when original reader
//    reads in chunks.
// 3. eomReason=ASYN_EOM_CNT when message was too long for
//    internal buffer of asynDriver.
    if (!interruptAccept) return; // too early to process records
    if (interface->ioAction == AsyncRead ||
        interface->ioAction == AsyncReadMore)
        interface->asynReadHandler(data, numchars, eomReason);
    else
    debug("AsynDriverInterface::intrCallbackOctet(%s, buffer=\"%s\", "
            "received=%d eomReason=%s) ioAction=%s\n",
        interface->clientName(), StreamBuffer(data, numchars).expand()(),
        numchars, eomReasonStr[eomReason&0x7], ioActionStr[interface->ioAction]);
#endif
// get asynchronous input
asynReadHandler(const char *buffer, int received, int eomReason)
    // Due to multithreading, timerExpired() might come at any time.
    // It queues the next poll request which is now useless because
    // we got asynchronous input.
    // Unfortunately, we  must be very careful not to block in this
    // function. That means, we must not call cancelRequest() from here!
    // We must also not call cancelRequest() in any other method that
    // might have been called in port thread context, like finish().
    // Luckily, that request cannot be active right now, because we are
    // inside the read handler of some other asynUser in the port thread.
    // Thus, it is sufficient to mark the request as obsolete by
    // setting ioAction=None. See handleRequest().
    debug("AsynDriverInterface::asynReadHandler(%s, buffer=\"%s\", "
        clientName(), StreamBuffer(buffer, received).expand()(),
        received, eomReasonStr[eomReason&0x7], ioActionStr[ioAction]);
#endif
    ioAction = None;
    long readMore = 1;
    if (received)
        // At the moment, it seems that asynDriver does not cut off
        // terminators for interrupt users and never sets eomReason.
        // This may change in future releases of asynDriver.
        asynStatus status;
        char deveos[16]; // I guess that is sufficient
        int deveoslen;
        if (eomReason & ASYN_EOM_EOS)
            // Terminator was cut off.
            // If terminator is handled by stream, then we must
            // restore the terminator, because the "real" terminator
            // might be longer than what the octet driver supports.
            if (!streameos)  // stream has not defined eos
                // Just handle eos as normal end condition
                // and don't try to add it.
                eomReason |= ASYN_EOM_END;
            else
                // Try to add terminator
                    pasynUser, deveos, sizeof(deveos)-1, &deveoslen);
                if (status == asynSuccess)
                    // We can't just append terminator to buffer, because
                    // we don't own that piece of memory.
                    // First process received data with cut-off terminator
                    readCallback(
                        StreamIoSuccess,
                        buffer, received);
                    // then add terminator
                    buffer = deveos;
                    received = deveoslen;
        else if (!streameos)
            // If terminator was not cut off and terminator was not
            // set by stream, cut it off now.
            if (status == asynSuccess && received >= deveoslen)
                int i;
                for (i = 1; i <= deveoslen; i++)
                    if (buffer[received - i] != deveos[deveoslen - i]) break;
                if (i > deveoslen) // terminator found
                    received -= deveoslen;
            eomReason & ASYN_EOM_END ?
            buffer, received);
    if (readMore)
        // wait for more input
        ioAction = AsyncReadMore;
        startTimer(readTimeout);
    debug("AsynDriverInterface::asynReadHandler(%s) readMore=%li, ioAction=%s \n",
        clientName(), readMore, ioActionStr[ioAction]);
// interface function: we want to receive an event
    if (receivedEvent & mask)
        // handle early events
        receivedEvent = 0;
        eventCallback(StreamIoSuccess);
        return true;
    eventMask = mask;
    ioAction = ReceiveEvent;
    startTimer(replytimeout_ms*0.001);
    return true;
void intrCallbackInt32(void* /*pvt*/, asynUser *pasynUser, epicsInt32 data)
    debug("AsynDriverInterface::intrCallbackInt32 (%s, %ld)\n",
        interface->clientName(), (long int) data);
    if (interface->eventMask)
        if (data & interface->eventMask)
            interface->eventMask = 0;
            interface->eventCallback(StreamIoSuccess);
        return;
    // store early events
    interface->receivedEvent = data;
void intrCallbackUInt32(void* /*pvt*/, asynUser *pasynUser,
    epicsUInt32 data)
    debug("AsynDriverInterface::intrCallbackUInt32 (%s, %ld)\n",
        return;
timerExpired()
    int autoconnect, connected;
    switch (ioAction)
        case ReceiveEvent:
            // timeout while waiting for event
            ioAction = None;
            eventCallback(StreamIoTimeout);
            return;
        case AsyncReadMore:
            // timeout after reading some async data
            // Deliver what we have.
            readCallback(StreamIoTimeout);
            // readCallback() may have started a new poll
            return;
        case AsyncRead:
            // No async input for some time, thus let's poll.
            // Due to multithreading, asynReadHandler() might be active
            // at the moment if another asynUser got input right now.
            // queueRequest might fail if another request was just queued
            pasynManager->isAutoConnect(pasynUser, &autoconnect);
            if (autoconnect && !connected)
                // has explicitely been disconnected
                // a poll would autoConnect which is not what we want
                // just retry later
            else
                // queue for read poll (no timeout)
                    asynQueuePriorityLow, -1.0);
                // continues with:
            return;
        default:
            error("INTERNAL ERROR (%s): timerExpired() unexpected ioAction %s\n",
                clientName(), ioActionStr[ioAction]);
            return;
#ifdef EPICS_3_14
epicsTimerNotify::expireStatus AsynDriverInterface::
    timerExpired();
    return noRestart;
#else
        static_cast<AsynDriverInterface*>(pcallback->user);
    interface->timerExpired();
#endif
    double queueTimeout = connecttimeout_ms*0.001;
    asynStatus status;
    ioAction = Connect;
    debug("AsynDriverInterface::connectRequest %s\n",
        clientName());
        asynQueuePriorityConnect, queueTimeout);
        error("%s connectRequest: pasynManager->queueRequest() failed: %s\n",
        return false;
    // continues with:
    //    handleRequest() -> connectHandler() -> connectCallback()
    // or handleTimeout() -> connectCallback(StreamIoTimeout)
    return true;
connectHandler()
    connectCallback(connectToAsynPort() ? StreamIoSuccess : StreamIoFault);
disconnectRequest()
    asynStatus status;
    ioAction = Disconnect;
    debug("AsynDriverInterface::disconnectRequest %s\n",
        clientName());
        asynQueuePriorityConnect, 0.0);
        error("%s disconnectRequest: pasynManager->queueRequest() failed: %s\n",
        return false;
    // continues with:
    //    handleRequest() -> disconnectHandler()
    return true;
disconnectHandler()
    int connected;
    asynStatus status;
    debug("AsynDriverInterface::disconnectHandler %s is %s disconnected\n",
        clientName(), !connected ? "already" : "not yet");
    if (connected)
        status = pasynCommon->disconnect(pvtCommon, pasynUser);
            error("%s connectRequest: pasynCommon->disconnect() failed: %s\n",
            disconnectCallback(StreamIoFault);
            return;
    disconnectCallback(StreamIoSuccess);
finish()
    debug("AsynDriverInterface::finish(%s) start\n",
        clientName());
    cancelTimer();
    ioAction = None;
    debug("AsynDriverInterface::finish(%s) done\n",
        clientName());
// asynUser callbacks to pasynManager->queueRequest()
void handleRequest(asynUser* pasynUser)
    switch (interface->ioAction)
        case None:
            // ignore obsolete poll request
            // see asynReadHandler()
            break;
        case Lock:
            interface->lockHandler();
            break;
        case Write:
            interface->writeHandler();
            break;
        case AsyncRead: // polled async input
        case AsyncReadMore:
        case Read:      // sync input
            interface->readHandler();
            break;
        case Connect:
            interface->connectHandler();
            break;
        case Disconnect:
            interface->disconnectHandler();
            break;
        default:
            error("INTERNAL ERROR (%s): "
                "handleRequest() unexpected ioAction %s\n",
                interface->clientName(), ioActionStr[interface->ioAction]);
void handleTimeout(asynUser* pasynUser)
        case Lock:
            interface->lockCallback(StreamIoTimeout);
            break;
        case Write:
            interface->writeCallback(StreamIoTimeout);
            break;
        case Read:
            interface->readCallback(StreamIoFault, NULL, 0);
            break;
        case AsyncReadMore:
            interface->readCallback(StreamIoTimeout, NULL, 0);
            break;
        case Connect:
            interface->connectCallback(StreamIoTimeout);
            break;
        case Disconnect:
            error("AsynDriverInterface %s: disconnect timeout\n",
                interface->clientName());
            // should not happen because of infinite timeout
            break;
        // No AsyncRead here because we don't use timeout when polling
        default:
            error("INTERNAL ERROR (%s): handleTimeout() "
                "unexpected ioAction %s\n",
RE: Stream device Szalata, Zenon M.
RE: Stream device Mark Rivers
Prev: problem in running application of gpib-device zhangdemin99
Next: synchronizing data to an event Ron Rechenmacher
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Stream device Szalata, Zenon M.
Next: RE: Stream device Szalata, Zenon M.
