1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: subArray INDX field set to 0 if NORD <= 0
To: "Gillingham, IJ (Ian)" <[email protected]>
Cc: [email protected]
Date: Fri, 09 Nov 2007 09:36:05 -0700
Hi Andrew,
I think this is what should be done to the subArray Record. I haven't tested it though.
Carl
*** 152,159 ****
         if (!pact && psa->pact) return(0);
         psa->pact = TRUE;
-         psa->udf=FALSE;
         recGblGetTimeStamp(psa);
       monitor(psa);
         /* process the forward scan link record */
--- 152,166 ----
         psa->pact = TRUE;
+         if (status) {
+            psa->udf = TRUE;
+            recGblSetSevr(psa,UDF_ALARM,INVALID_ALARM);
+         } else {
+            psa->udf=FALSE;
       monitor(psa);
*** 314,320 ****
         if (psa->nord <= 0)
            status = -1;
-            psa->indx = 0;
         return(status);
--- 321,326 ----
Gillingham, IJ (Ian) wrote:
This thread has come at a very timely moment, as I have been stumped for
a couple of days as to why a some of my waveform records have had their
INDX fields set to zero for no apparent reason.  My waveforms in
question contain status and interlock information from PLCs, which is
populated via streams/RS232. This has caused some of our interlock
tables to be referencing the wrong interlocks (those allocated to the
word at INDX = 0) and causing some confusion!  Having discussed this
thread with Pete Leicester, it transpires that this issue is more
widespread than realised. A fix would be much appreciated. In the mean
time, I shall probably have to monitor these INDX values and correct
them if/when they get reset to zero.
Ian Gillingham
Diamond Light Source
-----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Carl Lionberger Sent: 09 November 2007 01:01 To: Andrew Johnson Cc: [email protected] Subject: Re: subArray INDX field set to 0 if NORD <= 0
I'm pretty sure that the reason I put this in is the poor way the waveform record, on which subarray was based, posts invalid status. Certainly the subarray record support does not ever set INVALID and the waveform record does it only in a part that looks unreachable to me. The readValue() returns bad status but the process routine ignores it. It seems to me that the record should go invalid if it can't obtain
input.
Although I think Lewis' argument is compelling, I also think more needs to be done than just eliminating the assignment of indx to zero.
Carl
Andrew Johnson wrote:
Hi Lewis,
J. Lewis Muir wrote:
I have found that if a subArray record reads 0 elements into its array, it sets its INDX field to 0. Is this behavior intended? I would rather it not change its INDX field in this situation.
I agree that this behavior seems a little strange and I'm inclined to apply your patch (there's nothing mentioned in the Record Reference Manual about what should happen). The record's author is listed as Carl Lionberger who is still a member of this community - Carl, do you
have any comments on this change?
- Andrew
Carl Lionberger 510 486 7503
Software Developer, Engineering Division
Lawrence Berkeley National Laboratory
Re: subArray INDX field set to 0 if NORD <= 0 Andrew Johnson
RE: subArray INDX field set to 0 if NORD <= 0 Gillingham, IJ (Ian)
Prev: RE: subArray INDX field set to 0 if NORD <= 0 Gillingham, IJ (Ian)
Next: Re: Stream Raw converter and un/signed integrer Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: subArray INDX field set to 0 if NORD <= 0 Andrew Johnson
