1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: subArray INDX field set to 0 if NORD <= 0
To: [email protected]
Cc: [email protected]
Date: Fri, 09 Nov 2007 12:18:43 -0600
Hi Carl,
Thanks for the fixes. Should the get_array_info() function be changed to set *no_elements to zero when psa->udf is true? Currently it is set from psa->nelm on UDF, which looks wrong to me. Should the same apply in cvt_dbaddr()?
If you think there should be changes in the waveform record that make it behave more sensibly and won't break documented behavior I'd be happy to consider them.
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right.  When he states that something
is impossible, he is very probably wrong.  -- Arthur C. Clarke
Re: subArray INDX field set to 0 if NORD <= 0 J. Lewis Muir
RE: subArray INDX field set to 0 if NORD <= 0 Gillingham, IJ (Ian)
Re: subArray INDX field set to 0 if NORD <= 0 Carl Lionberger
Prev: Re: Stream Raw converter and un/signed integrer Emmanuel Mayssat
Next: Re: CA protocol dissector Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: subArray INDX field set to 0 if NORD <= 0 Carl Lionberger
Next: Re: subArray INDX field set to 0 if NORD <= 0 J. Lewis Muir
