1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: subArray INDX field set to 0 if NORD <= 0
To: [email protected]
Date: Fri, 16 Nov 2007 15:10:41 -0500
Hi, Andrew.
Have you made any more progress with this? Or are you waiting on a response from Carl to your below email from a week ago?
I'm willing to do a little testing if you have a patch you'd like someone to try out.
-lewis
On 11/9/07 1:18 PM, Andrew Johnson wrote:
Hi Carl,
Thanks for the fixes. Should the get_array_info() function be changed to set *no_elements to zero when psa->udf is true? Currently it is set from psa->nelm on UDF, which looks wrong to me. Should the same apply in cvt_dbaddr()?
If you think there should be changes in the waveform record that make it behave more sensibly and won't break documented behavior I'd be happy to consider them.
- Andrew
Re: subArray INDX field set to 0 if NORD <= 0 Andrew Johnson
RE: subArray INDX field set to 0 if NORD <= 0 Gillingham, IJ (Ian)
Re: subArray INDX field set to 0 if NORD <= 0 Carl Lionberger
Prev: Re: SDDS lapack compile error Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO]
Next: Re: SDDS lapack compile error Janet Anderson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: subArray INDX field set to 0 if NORD <= 0 Andrew Johnson
Next: Re: subArray INDX field set to 0 if NORD <= 0 Andrew Johnson
