J. Lewis Muir wrote:
I just heard back from Carl who sent me another patch which I have applied. I'm willing to do a little testing if you have a patch you'd like someone to try out. Great, I'm attaching the latest subArrayRecord.c file to this email (it has gone through too many cosmetic changes since R3.14.9 to be worth using a .patch file) which I have compiled but not tested. Please check it out and report back. Thanks, â Andrew -- When a distinguished but elderly scientist states that something is possible, he is almost certainly right. When he states that something is impossible, he is very probably wrong. -- Arthur C. Clarke /*************************************************************************\
* Copyright (c) 2002 Lawrence Berkeley Laboratory,The Control Systems
* Group, Systems Engineering Department
* EPICS BASE Versions 3.13.7
* and higher are distributed subject to a Software License Agreement found
* in file LICENSE that is included with this distribution.
/* recSubArray.c */
/* recSubArray.c - Record Support Routines for SubArray records
* Author: Carl Lionberger
* Date: 090293
* NOTES:
* Derived from waveform record.
* Modification Log:
#include <stddef.h>
#include <stdlib.h>
#include <stdarg.h>
#include <stdio.h>
#include <string.h>
#include "dbDefs.h"
#include "epicsPrint.h"
#include "alarm.h"
#include "dbAccess.h"
#include "dbEvent.h"
#include "dbFldTypes.h"
#include "dbScan.h"
#include "devSup.h"
#include "errMdef.h"
#include "recSup.h"
#include "recGbl.h"
#define GEN_SIZE_OFFSET
#include "subArrayRecord.h"
#undef GEN_SIZE_OFFSET
#include "epicsExport.h"
/* Create RSET - Record Support Entry Table*/
#define report NULL
#define initialize NULL
static long init_record(subArrayRecord *psa, int pass);
static long process(subArrayRecord *psa);
#define special NULL
#define get_value NULL
static long cvt_dbaddr(DBADDR *paddr);
static long get_array_info(DBADDR *paddr, long *no_elements, long *offset);
static long put_array_info(DBADDR *paddr, long nNew);
static long get_units(DBADDR *paddr, char *units);
static long get_precision(DBADDR *paddr, long *precision);
#define get_enum_str NULL
#define get_enum_strs NULL
#define put_enum_str NULL
static long get_graphic_double(DBADDR *paddr, struct dbr_grDouble *pgd);
static long get_control_double(DBADDR *paddr, struct dbr_ctrlDouble *pcd);
#define get_alarm_double NULL
rset subArrayRSET={
RSETNUMBER,
report,
initialize,
init_record,
process,
special,
get_value,
cvt_dbaddr,
get_array_info,
put_array_info,
get_units,
get_precision,
get_enum_str,
get_enum_strs,
put_enum_str,
get_graphic_double,
get_control_double,
get_alarm_double
epicsExportAddress(rset,subArrayRSET);
struct sadset { /* subArray dset */
long number;
DEVSUPFUN dev_report;
DEVSUPFUN init;
DEVSUPFUN init_record; /*returns: (-1,0)=>(failure,success)*/
DEVSUPFUN get_ioint_info;
DEVSUPFUN read_sa; /*returns: (-1,0)=>(failure,success)*/
/*sizes of field types*/
static int sizeofTypes[] = {MAX_STRING_SIZE,1,1,2,2,4,4,4,8,2};
static void monitor(subArrayRecord *psa);
static long readValue(subArrayRecord *psa);
struct sadset *pdset;
if (pass==0){
if (psa->malm <= 0)
psa->malm = 1;
if (psa->ftvl > DBF_ENUM)
psa->ftvl = 2;
psa->bptr = calloc(psa->malm, sizeofTypes[psa->ftvl]);
psa->nord = 0;
return 0;
/* must have dset defined */
if (!(pdset = (struct sadset *)(psa->dset))) {
recGblRecordError(S_dev_noDSET,(void *)psa,"sa: init_record");
return S_dev_noDSET;
/* must have read_sa function defined */
if ( (pdset->number < 5) || (pdset->read_sa == NULL) ) {
recGblRecordError(S_dev_missingSup,(void *)psa,"sa: init_record");
return S_dev_missingSup;
if (pdset->init_record)
return (*pdset->init_record)(psa);
return 0;
struct sadset *pdset = (struct sadset *)(psa->dset);
long status;
unsigned char pact=psa->pact;
if ((pdset==NULL) || (pdset->read_sa==NULL)) {
psa->pact=TRUE;
recGblRecordError(S_dev_missingSup, (void *)psa, "read_sa");
if (pact && psa->busy) return 0;
status=readValue(psa); /* read the new value */
if (!pact && psa->pact) return 0;
psa->pact = TRUE;
recGblGetTimeStamp(psa);
psa->udf = !!status; /* 0 or 1 */
if (status)
recGblSetSevr(psa, UDF_ALARM, INVALID_ALARM);
monitor(psa);
/* process the forward scan link record */
recGblFwdLink(psa);
psa->pact=FALSE;
return 0;
subArrayRecord *psa = (subArrayRecord *) paddr->precord;
paddr->pfield = psa->bptr;
paddr->no_elements = psa->malm;
paddr->field_type = psa->ftvl;
paddr->field_size = sizeofTypes[psa->ftvl];
paddr->dbr_field_type = psa->ftvl;
return 0;
if (psa->udf)
*no_elements = 0;
else
*no_elements = psa->nord;
*offset = 0;
return 0;
if (nNew > psa->malm)
psa->nord = psa->malm;
else
psa->nord = nNew;
return 0;
strncpy(units, psa->egu, DB_UNITS_SIZE);
return 0;
int fieldIndex = dbGetFieldIndex(paddr);
*precision = psa->prec;
if (fieldIndex != subArrayRecordVAL)
recGblGetPrec(paddr, precision);
return 0;
switch (dbGetFieldIndex(paddr)) {
case subArrayRecordVAL:
pgd->upper_disp_limit = psa->hopr;
pgd->lower_disp_limit = psa->lopr;
break;
case subArrayRecordINDX:
pgd->upper_disp_limit = psa->malm - 1;
pgd->lower_disp_limit = 0;
break;
case subArrayRecordNELM:
pgd->upper_disp_limit = psa->malm;
pgd->lower_disp_limit = 1;
break;
default:
recGblGetGraphicDouble(paddr, pgd);
return 0;
pcd->upper_ctrl_limit = psa->hopr;
pcd->lower_ctrl_limit = psa->lopr;
break;
pcd->upper_ctrl_limit = psa->malm - 1;
pcd->lower_ctrl_limit = 0;
break;
pcd->upper_ctrl_limit = psa->malm;
pcd->lower_ctrl_limit = 1;
break;
default:
recGblGetControlDouble(paddr, pcd);
return 0;
unsigned short monitor_mask;
monitor_mask = recGblResetAlarms(psa);
monitor_mask |= (DBE_LOG|DBE_VALUE);
db_post_events(psa, psa->bptr, monitor_mask);
return;
long status;
struct sadset *pdset = (struct sadset *) (psa->dset);
if (psa->nelm > psa->malm)
psa->nelm = psa->malm;
if (psa->indx >= psa->malm)
psa->indx = psa->malm - 1;
status = (*pdset->read_sa)(psa);
if (psa->nord <= 0)
status = -1;
return status;
| ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
