1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Power Supply Record?
To: EPICS Tech Talk <[email protected]>
Date: Thu, 15 Nov 2007 12:24:27 -0600
The DZero Experiment at Fermilab has a HV record that includes a state machine. Fritz Bartlett, the developer of our HV record, has just become a "Guest Scientist Retiree" so he is still available for consultation. We have a tutorial on our HV system at -
http://www-d0online.fnal.gov/www/groups/ctl/tutorials/high-voltage- tutorial.pdf.
I can make the software available for those who are interested.
Geoff
On Nov 15, 2007, at 6:49 AM, Ralph Lange wrote:
I strongly agree.
Creating templates for different power supply types are probably a good way to go in most cases.
We even broke up our power supply templates into smaller units, most of which are only consisting of a single record. (Templates for "status word", "status bit", "command word", "command bit", ...)
The only exception - maybe - being a case where you have a large number of very similar, very complex power supplies that need a complex state machine to be operated. The only example that I know of: high voltage power supplies in large detectors.
Even in such a case I would consider putting only the complex state machine into a separate custom (or generic subroutine) record.
Good luck!
Ralph
Luedeke Andreas wrote:
Susanna Jacobson wrote:
[...] we are considering writing a custom Power Supply record. [...]
I would also welcome any advice or cautions you have, based on your experience in this area. [...]
Hi Susanna,
I had a similar idea 8 years ago for some in-house developed power supply at PSI.
Luckily I got some advice not to do it that way (Thanks Bob!).
If you use one record per power supply, your application will suffer from a lack of expandability, flexibility and usability.
Power Supply Record? Susanna Jacobson
Re: Power Supply Record? Luedeke Andreas
Re: Power Supply Record? Ralph Lange
Prev: RE: iocLogServer simple browser Jeff Hill
Next: Re: Power Supply Record? Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Power Supply Record? Ralph Lange
Next: Re: Power Supply Record? Claude Saunders
