1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Immediate Software Developer Job Opening at SLAC (LCLS)
To: <[email protected]>
Date: Thu, 15 Nov 2007 21:34:11 -0800
The Particle Physics & Astro-Physics Research Engineering Group at Stanford/SLAC (http://www.slac.stanford.edu)
is looking for a software developer. If you want to find more or if you like to email your resume, please contact Gunther Haller [email protected]
 The Linac Coherent Light Source (LCLS), located at SLAC, will begin
operation in 2009 as the world's first x-ray free-electron laser,
producing ultra-fast pulses of coherent x-rays with unprecedented
brightness.  A suite of x-ray instruments for exploiting the unique
LCLS scientific capabilities will be produced.  All these different
instruments will adopt a common control system. This system is a
heterogeneous platform comprised of VME and cPCI single board
computers running RTEMS and servers running Linux.  The successful
candidate will develop client and server applications to control and
monitor the vacuum system, motion, viewing, the laser system and the
various components of the different LCLS & LUSI experiments.
  Required Skills
  The candidate must possess an advanced degree (MS or PhD) in
computer science, mathematics, physics, engineering, or related
field or equivalent combination of education and training.  The
applicant must have extensive demonstrated programming skills with
C and C++.
In depth knowledge of the EPICS channel access protocol, of EPICS
records, fields, databases and sequencers is required. Experience
with programming host-based and target IOCs, experience with device
support and with client tools like MEDM/EDM, Strip Tool, ALH are
 desired.
 Excellent communications skills and ability to work well in a
research and development team are required.
Dr. Gunther Haller
Stanford University/SLAC
MS 96
P.O. 20450
Stanford, CA 94309
T. (650) 926-4257
F. (650) 926-2923
Prev: building device support on external library - help needed John Dobbins
Next: EPICS on RTEMS Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Problem solved : building device support on external library - help needed John Dobbins
