1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem solved : building device support on external library - help needed
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 16 Nov 2007 09:12:25 -0500
I neglected to mention the device support code is C++. The library header files did not have #ifdef __cplusplus ....
Once I fixed that it was easy. Thanks for the nifty build system. I always dread that it will stop working in some way I don't understand but it makes life so easy!
John
disclaimer - pardon me if I'm being stupid here
I am trying to build device support based on a library external to EPICS for a
softIOC on linux.
Call the external library libXXX = /path_to_libXXX/libXXX.so
In the src directory for devXXX_SUPPORT I edit the Makefile to add the lines
USR_INCLUDES += -I/path_to_XXX_related_include_files/
XXX_DIR = /path_to_libXXX/
devXXX_SUPPORT_LIBS += XXX
Device support then builds OK.
I do ldd libdevXXX_SUPPORT.so and see it depends on libXXX.so
However, I next try to build an IOC to test the newly created device support but
I can't figure out how to do this correctly.
I edit RELEASE for the testIOC to point to device support.
In the src directory for testIOC I edit Makefile to add the line:
testIOC_LIBS += devXXX_SUPPORT
but that is not enough because I get errors on link of testIOC of the type
libdevXXX_SUPPORT.so: undefined reference to some function from libXXX
I have tried indicating the location of libXXX in the testIOC Makefile but that
doesn't seem to help, or I am doing it incorrectly.
Guidance would be appreciated.
John Dobbins Cornell University
Prev: Re: EPICS on RTEMS Eric Norum
Next: SDDS lapack compile error Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO]
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Immediate Software Developer Job Opening at SLAC (LCLS) Haller, Gunther
