1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: SDDS lapack compile error
From: "Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO]" <[email protected]>
To: <[email protected]>
Date: Fri, 16 Nov 2007 11:26:55 -0600
     I am using Linux Fedora Core 6 and EPICS R3.14.9.  I need EPICS Extension StripTool.
     Using StripTool2_5_12_0 which needs SDDS.  I am using SDDS.2.3.1.  At this time I am also using medm3_1_2_1 and probe1_1_5_1 , but may need more later.
     Compiling SDDS ends with the following errors:
Installing library ../../../../lib/linux-x86/liblevmar.a
/usr/bin/ranlib ../../../../lib/linux-x86/liblevmar.a
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall    -I../../include -DHAVE_LAPACK      -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../lmdemo.c
/usr/bin/g++ -o lmdemo  -L/ade/appl-ts1/epics/R3.14.9/extensions/lib/linux-x86 -Wl,-rpath,/ade/appl-ts1/epics/R3.14.9/extensions/lib/linux-x86                 lmdemo.o    -llevmar  -lpthread   -lreadline -lcurses -lm -lrt -llapack -lblas  -lgcc
/usr/bin/ld: cannot find -llapack
collect2: ld returned 1 exit status
make[2]: *** [lmdemo] Error 1
make[2]: Leaving directory `/ade/appl-ts1/epics/R3.14.9/extensions/src/SDDS/levmar/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory `/ade/appl-ts1/epics/R3.14.9/extensions/src/SDDS/levmar'
make: *** [levmar.install] Error 2
      After SDDS compiling reaches these errors and stops, directory  "epics/R3.14.9/extensions/bin/linux-x86/" contains many sdds* programs and "epics/R3.14.9/extensions/lib/linux-x86/" contains:
libfftpack.a
liblevmar.a
libmatlib.a
libmdbcommon.a
libmdblib.a
libmdbmth.a
libmdbplt.a
libmeschach.a
libnamelist.a
librpnlib.a
libSDDS1.a
libSDDS1c.a
     I can now compile StripTool which is what I need.
QUESTIONS:
     Has StripTool really been compiled sucessfully ?   Seems to work.
     How do I add "lapack" to make the "ld" linker happy?  Is "lapack" needed for other extensions?
Billy R. Adams
Re: SDDS lapack compile error Rodney R. Porter
Re: SDDS lapack compile error Steven Hartman
Re: SDDS lapack compile error Janet Anderson
Prev: Problem solved : building device support on external library - help needed John Dobbins
Next: Re: SDDS lapack compile error Rodney R. Porter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
