1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: building EPICS base on Mac OS X 10.5 (Leopard)
To: [email protected]
Date: Mon, 19 Nov 2007 13:43:54 -0500
Has anyone successfully built EPICS base 3.14.9 on Mac OS X 10.5 (Leopard) for X86? It fails when I attempt to run make.
thanks,
tom
I get the following result and error when running make:
t6p@i73072: make
make -C config install
perl /Library/EPICS/Versions/Current/configure/tools/makeMakefile.pl O.darwin-x86 ../..
mkdir O.Common
make -C O.darwin-x86 -f ../Makefile TOP=../.. T_A=darwin-x86 install
make[2]: Nothing to be done for `install'.
make -C configure install
mkdir O.Common
perl /Library/EPICS/Versions/Current/configure/tools/convertRelease.pl -h darwin-x86 CONFIG_APP_INCLUDE
make -C src install
make -C libCom install
perl /Library/EPICS/Versions/Current/configure/tools/makeMakefile.pl O.darwin-x86 ../../..
mkdir O.Common
make -C O.darwin-x86 -f ../Makefile TOP=../../.. T_A=darwin-x86 install
perl ../../../src/libCom/misc/makeEpicsVersion.pl /Library/EPICS/ Versions/Current/configure/CONFIG_BASE_VERSION ../O.Common
Building epicsVersion.h from /Library/EPICS/Versions/Current/configure/ CONFIG_BASE_VERSION
Found EPICS Version 3.14.9
Installing generated generic include file ../../../include/ epicsVersion.h
/usr/bin/cc -c -DUNIX -Ddarwin -ansi -O3 -Wall -fno-common -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../ src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/ cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/ cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib - I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/ libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/ gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib - I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/ libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Darwin -I../../../include -I/opt/local/ include -I/sw/include ../../../src/libCom/bucketLib/bucketLib.c
/usr/libexec/gcc/i686-apple-darwin8/4.0.1/as: assembler (/usr/bin/../ libexec/gcc/darwin/i386/as or /usr/bin/../local/libexec/gcc/darwin/ i386/as) for architecture i386 not installed
Installed assemblers are:
/usr/bin/../libexec/gcc/darwin/ppc64/as for architecture ppc64
/usr/bin/../libexec/gcc/darwin/x86_64/as for architecture x86_64
make[3]: *** [bucketLib.o] Error 1
make[2]: *** [install.darwin-x86] Error 2
make[1]: *** [libCom.install] Error 2
make: *** [src.install] Error 2
t6p@i73072:
Re: building EPICS base on Mac OS X 10.5 (Leopard) yamamoto
RE: building EPICS base on Mac OS X 10.5 (Leopard) Denison, PN (Peter)
Prev: Re: Problem with assert in dbLock.c Andrew Johnson
Next: Re: Problem with assert in dbLock.c David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: 2007 EPICS Meeting (Knoxville) Presentations Kay-Uwe Kasemir
Next: Re: building EPICS base on Mac OS X 10.5 (Leopard) yamamoto
