Here is a list of /usr/libexec/gcc on my MacOSX10.5 machine.
/usr/libexec/gcc:
total used in directory 0 available 446416
drwxr-xr-x 5 root wheel 170 Oct 31 08:41 .
drwxr-xr-x@ 94 root wheel 3196 Oct 31 08:41 ..
drwxr-xr-x 6 root wheel 204 Sep 24 07:42 darwin
drwxr-xr-x 3 root wheel 102 Sep 24 07:37 i686-apple-darwin9
drwxr-xr-x 3 root wheel 102 Sep 24 07:37 powerpc-apple-darwin9
and contents in /usr/lib/exec/gcc/darwin
/usr/libexec/gcc/darwin:
drwxr-xr-x 6 root wheel 204 Sep 24 07:42 .
drwxr-xr-x 5 root wheel 170 Oct 31 08:41 ..
drwxr-xr-x 3 root wheel 102 Sep 24 07:43 i386
drwxr-xr-x 3 root wheel 102 Sep 24 07:43 ppc
drwxr-xr-x 3 root wheel 102 Sep 24 07:43 ppc64
drwxr-xr-x 3 root wheel 102 Sep 24 07:43 x86_64
The error message you sent says:
>include -I/sw/include ../../../src/libCom/bucketLib/bucketLib.c
>/usr/libexec/gcc/i686-apple-darwin8/4.0.1/as: assembler (/usr/bin/../
>libexec/gcc/darwin/i386/as or /usr/bin/../local/libexec/gcc/darwin/
>i386/as) for architecture i386 not installed
>Installed assemblers are:
>/usr/bin/../libexec/gcc/darwin/ppc64/as for architecture ppc64
>/usr/bin/../libexec/gcc/darwin/x86_64/as for architecture x86_64
So, I suggest to check your installation of Xcode.
my Env:
bash-3.2$ uname -a
Darwin xxx.yyy.zzz 9.0.0 Darwin Kernel Version 9.0.0: Tue Oct 9 21:37:58 PDT 2007; root:xnu-1228~\1/RELEASE_PPC Power Macintosh
bash-3.2$ cc --version
powerpc-apple-darwin9-gcc-4.0.1 (GCC) 4.0.1 (Apple Inc. build 5465)
Copyright (C) 2005 Free Software Foundation, Inc.
You need to install epicsMath.h from Eric.
You may also need to edit configure/os/CONFIG.Common.darwin-ppcx86 to
delete
-isysroot /Developer/SDKs/MacOSX10.4u.sdk
and
-Wl,-syslibroot,/Developer/SDKs/MacOSX10.4u.sdk
from options.
Hope this help,
Noboru
--- "Tom Pelaia" <[email protected]> ---
>Has anyone successfully built EPICS base 3.14.9 on Mac OS X 10.5
>(Leopard) for X86? It fails when I attempt to run make.
>thanks,
>tom
>I get the following result and error when running make:
>t6p@i73072: make
>make -C config install
>perl /Library/EPICS/Versions/Current/configure/tools/makeMakefile.pl
>O.darwin-x86 ../..
>mkdir O.Common
>make -C O.darwin-x86 -f ../Makefile TOP=../.. T_A=darwin-x86 install
>make[2]: Nothing to be done for `install'.
>make -C configure install
>O.darwin-x86 ../..
>mkdir O.Common
>perl /Library/EPICS/Versions/Current/configure/tools/convertRelease.pl
>-h darwin-x86 CONFIG_APP_INCLUDE
>make -C src install
>make -C libCom install
>O.darwin-x86 ../../..
>mkdir O.Common
>make -C O.darwin-x86 -f ../Makefile TOP=../../.. T_A=darwin-x86 install
>perl ../../../src/libCom/misc/makeEpicsVersion.pl /Library/EPICS/
>Versions/Current/configure/CONFIG_BASE_VERSION ../O.Common
>Building epicsVersion.h from /Library/EPICS/Versions/Current/configure/
>CONFIG_BASE_VERSION
>Found EPICS Version 3.14.9
>Installing generated generic include file ../../../include/
>epicsVersion.h
>/usr/bin/cc -c -DUNIX -Ddarwin -ansi -O3 -Wall
>-fno-common -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../
>src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/
>cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/
>cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -
>I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/
>libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/
>gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -
>I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/
>libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs
>-I../../../include/os/Darwin -I../../../include -I/opt/local/
>make[3]: *** [bucketLib.o] Error 1
>make[2]: *** [install.darwin-x86] Error 2
>make[1]: *** [libCom.install] Error 2
>make: *** [src.install] Error 2
>t6p@i73072:
- Re: building EPICS base on Mac OS X 10.5 (Leopard) Tom Pelaia
- building EPICS base on Mac OS X 10.5 (Leopard) Tom Pelaia
Re: subArray INDX field set to 0 if NORD <= 0 J. Lewis Muir
RE: building EPICS base on Mac OS X 10.5 (Leopard) Denison, PN (Peter)
<2007>
2025
2026
<2007>
2025
2026
