I discovered that the problem was due to an incomplete installation of
developer tools. Specifically, the scripts which get put into /usr/
bin to support multiple developer tool installation were missing. If
you have installed the CHUD performance tools, it is important to
first uninstall the CHUD performance tools before installing Xcode
3.0. The CHUD performance tools come with an uninstaller application.
After I uninstalled the CHUD performance tools and then reinstalled
Xcode 3.0, I was able to build EPICS after applying the finite/
isfinite patch posted in previous tech talk postings.
thanks,
tom
On Nov 19, 2007, at 8:34 PM, [email protected] wrote:
Here is a list of /usr/libexec/gcc on my MacOSX10.5 machine.
/usr/libexec/gcc:
total used in directory 0 available 446416
drwxr-xr-x 5 root wheel 170 Oct 31 08:41 .
drwxr-xr-x@ 94 root wheel 3196 Oct 31 08:41 ..
drwxr-xr-x 6 root wheel 204 Sep 24 07:42 darwin
drwxr-xr-x 3 root wheel 102 Sep 24 07:37 i686-apple-darwin9
drwxr-xr-x 3 root wheel 102 Sep 24 07:37 powerpc-apple-darwin9
and contents in /usr/lib/exec/gcc/darwin
/usr/libexec/gcc/darwin:
drwxr-xr-x 6 root wheel 204 Sep 24 07:42 .
drwxr-xr-x 5 root wheel 170 Oct 31 08:41 ..
drwxr-xr-x 3 root wheel 102 Sep 24 07:43 i386
drwxr-xr-x 3 root wheel 102 Sep 24 07:43 ppc
drwxr-xr-x 3 root wheel 102 Sep 24 07:43 ppc64
drwxr-xr-x 3 root wheel 102 Sep 24 07:43 x86_64
The error message you sent says:
include -I/sw/include ../../../src/libCom/bucketLib/bucketLib.c
/usr/libexec/gcc/i686-apple-darwin8/4.0.1/as: assembler (/usr/bin/../
libexec/gcc/darwin/i386/as or /usr/bin/../local/libexec/gcc/darwin/
i386/as) for architecture i386 not installed
Installed assemblers are:
/usr/bin/../libexec/gcc/darwin/ppc64/as for architecture ppc64
/usr/bin/../libexec/gcc/darwin/x86_64/as for architecture x86_64
So, I suggest to check your installation of Xcode.
my Env:
bash-3.2$ uname -a
Darwin xxx.yyy.zzz 9.0.0 Darwin Kernel Version 9.0.0: Tue Oct 9
21:37:58 PDT 2007; root:xnu-1228~\1/RELEASE_PPC Power Macintosh
bash-3.2$ cc --version
powerpc-apple-darwin9-gcc-4.0.1 (GCC) 4.0.1 (Apple Inc. build 5465)
Copyright (C) 2005 Free Software Foundation, Inc.
You need to install epicsMath.h from Eric.
You may also need to edit configure/os/CONFIG.Common.darwin-ppcx86 to
delete
-isysroot /Developer/SDKs/MacOSX10.4u.sdk
and
-Wl,-syslibroot,/Developer/SDKs/MacOSX10.4u.sdk
from options.
Hope this help,
Noboru
--- "Tom Pelaia" <[email protected]> ---
Has anyone successfully built EPICS base 3.14.9 on Mac OS X 10.5
(Leopard) for X86? It fails when I attempt to run make.
thanks,
tom
I get the following result and error when running make:
t6p@i73072: make
make -C config install
perl /Library/EPICS/Versions/Current/configure/tools/makeMakefile.pl
O.darwin-x86 ../..
mkdir O.Common
make -C O.darwin-x86 -f ../Makefile TOP=../.. T_A=darwin-x86 install
make[2]: Nothing to be done for `install'.
make -C configure install
O.darwin-x86 ../..
mkdir O.Common
convertRelease.pl
-h darwin-x86 CONFIG_APP_INCLUDE
make -C src install
make -C libCom install
O.darwin-x86 ../../..
mkdir O.Common
make -C O.darwin-x86 -f ../Makefile TOP=../../.. T_A=darwin-x86
install
perl ../../../src/libCom/misc/makeEpicsVersion.pl /Library/EPICS/
Versions/Current/configure/CONFIG_BASE_VERSION ../O.Common
Building epicsVersion.h from /Library/EPICS/Versions/Current/
configure/
CONFIG_BASE_VERSION
Found EPICS Version 3.14.9
Installing generated generic include file ../../../include/
epicsVersion.h
/usr/bin/cc -c -DUNIX -Ddarwin -ansi -O3 -Wall
-fno-common -fPIC -I. -I.. -I../../../src/libCom/bucketLib -
I../../../
src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/
cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/
cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/
ellLib -
I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/
libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/
gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -
I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/
libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/
tsDefs
-I../../../include/os/Darwin -I../../../include -I/opt/local/
make[3]: *** [bucketLib.o] Error 1
make[2]: *** [install.darwin-x86] Error 2
make[1]: *** [libCom.install] Error 2
make: *** [src.install] Error 2
t6p@i73072:
- building EPICS base on Mac OS X 10.5 (Leopard) Tom Pelaia
- Re: building EPICS base on Mac OS X 10.5 (Leopard) yamamoto
RE: building EPICS base on Mac OS X 10.5 (Leopard) Denison, PN (Peter)
Re: subArray INDX field set to 0 if NORD <= 0 Andrew Johnson
<2007>
2025
2026
<2007>
2025
2026
ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
