On Nov 19, 2007, at 1:26 PM, David Dudley wrote:
Got farther, but not all the way. I assume that the
MessageQueueTest shouldn't take 'minutes', as none of the others
took over at most about 5-10 seconds.
Not sure what the timer test failing is. It was working before,
and looks like an upgrade must have killed it. Also, it isn't very
consistent. I've seen it fail tests 2-5, 2-4, and 2-3 at various
times. The MessageQueTest runs for quite a while, and then I
killed it.
Actually the message queue test *is* supposed to run for a while. It
even says so:
ok 55 - Send with no receiver
ok 56 - receive into undersized buffer returned error (-1)
# Single receiver, single sender tests:
# priority-based scheduler, sent 4 messages
# scheduler not strict priority, sent 5 messages
ok 57 - 10 of 10 messages sent with sender pauses
# Single receiver, multiple sender tests:
# This test takes 5 minutes...
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- Re: Problem with assert in dbLock.c David Dudley
- Problem with assert in dbLock.c David Dudley
- Re: Problem with assert in dbLock.c Andrew Johnson
<2007>
2025
2026
<2007>
2025
2026
ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
