Let the tests run much longer, and here's the final score.
bash-3.2$ gmake -s runtests
epicsUnitTestTest..........ok
epicsCalcTest..............ok
epicsAlgorithmTest.........ok
epicsMathTest..............ok
epicsStdioTest.............ok
epicsStringTest............ok
epicsTimeTest..............ok
epicsThreadTest............ok
epicsThreadPriorityTest....ok
epicsThreadPrivateTest.....ok
epicsExitTest..............ok
epicsTimerTest.............FAILED tests 2-3
Failed 2/40 tests, 95.00% okay
ringPointerTest............ok
epicsEventTest.............ok
epicsMutexTest.............ok
epicsExceptionTest.........ok
epicsMessageQueueTest......ok
macEnvExpandTest...........ok
blockingSockTest...........ok
Failed Test Stat Wstat Total Fail Failed List of Failed
epicsTimerTest.t 40 2 5.00% 2-3
Failed 1/19 test scripts, 94.74% okay. 2/1306 subtests failed, 99.85%
okay.
gmake[3]: *** [runtests] Error 255
gmake[2]: *** [runtests.netbsd-x86] Error 2
gmake[1]: *** [libCom/test.runtests] Error 2
gmake: *** [src.runtests] Error 2
bash-3.2$
The timer test is the only item that failed, it looks like.
Where do I look for that?
David
>>> Eric Norum <[email protected]> 11/19/2007 1:34 PM >>>
On Nov 19, 2007, at 1:26 PM, David Dudley wrote:
> Got farther, but not all the way. I assume that the
> MessageQueueTest shouldn't take 'minutes', as none of the others
> took over at most about 5-10 seconds.
> Not sure what the timer test failing is. It was working before,
> and looks like an upgrade must have killed it. Also, it isn't very
> consistent. I've seen it fail tests 2-5, 2-4, and 2-3 at various
> times. The MessageQueTest runs for quite a while, and then I
> killed it.
Actually the message queue test *is* supposed to run for a while. It
even says so:
ok 55 - Send with no receiver
ok 56 - receive into undersized buffer returned error (-1)
# Single receiver, single sender tests:
# priority-based scheduler, sent 4 messages
# scheduler not strict priority, sent 5 messages
ok 57 - 10 of 10 messages sent with sender pauses
# Single receiver, multiple sender tests:
# This test takes 5 minutes...
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
- Re: Problem with assert in dbLock.c Eric Norum
- Re: Problem with assert in dbLock.c Andrew Johnson
- Problem with assert in dbLock.c David Dudley
- Re: Problem with assert in dbLock.c David Dudley
<2007>
2025
2026
<2007>
2025
2026
