1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with assert in dbLock.c
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Mon, 19 Nov 2007 13:51:59 -0600
On Nov 19, 2007, at 1:45 PM, David Dudley wrote:
Let the tests run much longer, and here's the final score.
The timer test is the only item that failed, it looks like.
Where do I look for that?
cd <epics_top>/src/libCom/test
Then run the test by hand. Here's what I do for Mac OS X -- you'll have to make appropriate substitutions (replace darwin-x86 with netbsd-x86) for your host architecture.
 ./O.darwin-x86/epicsTimerTest
1..40
# Testing timer accuracy
ok  1 - timerCount == nTimers
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Re: Problem with assert in dbLock.c David Dudley
Re: Problem with assert in dbLock.c Andrew Johnson
Re: Problem with assert in dbLock.c Eric Norum
Prev: Re: Problem with assert in dbLock.c David Dudley
Next: Re: Problem with assert in dbLock.c David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
