Well, everything seems to work, but have a problem with accuracy. It
isn't consistent, with an error of 0.011... but relatively close.
Rebuilding everything makes the system work without problem, now.
David
>>> Eric Norum <[email protected]> 11/19/2007 1:51 PM >>>
On Nov 19, 2007, at 1:45 PM, David Dudley wrote:
> Let the tests run much longer, and here's the final score.
> The timer test is the only item that failed, it looks like.
> Where do I look for that?
cd <epics_top>/src/libCom/test
Then run the test by hand. Here's what I do for Mac OS X -- you'll
have to make appropriate substitutions (replace darwin-x86 with
netbsd-x86) for your host architecture.
./O.darwin-x86/epicsTimerTest
1..40
# Testing timer accuracy
ok 1 - timerCount == nTimers
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
- Problem with assert in dbLock.c David Dudley
- Re: Problem with assert in dbLock.c Andrew Johnson
- Re: Problem with assert in dbLock.c David Dudley
- Re: Problem with assert in dbLock.c Eric Norum
<2007>
2025
2026
<2007>
2025
2026
