1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Java CA context cleanup issues on Linux?
To: tech talk <[email protected]>
Date: Tue, 04 Dec 2007 17:00:55 -0500
Hello Lewis:
Thanks for the info.
Our setups are different, but not that much.
Your example works for me with the PVs hosted on a VME IOC and the following Linux workstation setup:
* Dual Intel Xeon 2.8 GHz w/ hyper-threading enabled
* Red Hat Enterprise Linux WS release 3 (Taroon Update 9)
* EPICS 3.14.8.2
* JCA 2.3.1
* Sun's jdk1.5.0_12
What is your setup?
What happens if you change JNI_THREAD_SAFE to JNI_SINGLE_THREADED?
No errors with JNI_SINGLE_THREADED, but the example is a cooked-down
version of a bigger application that should really be JNI_THREAD_SAFE,
uses async. connection handling etc.
Same EPICS base and JCA as you.
JDK 1.5.0_9 or 1.5.0_13
Data source is soft IOC on either the same or different host.
Test host either RedHat Enterprise Linux Client release 5.1 with
kernel 2.6.18-53.el5 and g++ (GCC) 4.1.2 20070626 (Red Hat 4.1.2-14),
or the older Red Hat Enterprise Linux AS release 4 (Nahant Update 4) with
kernel 2.6.9-42.EL and g++ (GCC) 3.4.6 20060404 (Red Hat 3.4.6-3).
Both are single-core CPUs.
One is an Intel Xeon 2.8 GHz and /proc/cpuinfo shows the 'ht' flag,
but I guess hyperthreading is not enabled, because I see a single CPU.
-Kay
Re: Java CA context cleanup issues on Linux? J. Lewis Muir
Prev: RE: Multiple IOC Jeff Hill
Next: Re: Multiple IOC Robert Emery
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Java CA context cleanup issues on Linux? J. Lewis Muir
Next: Re: Java CA context cleanup issues on Linux? J. Lewis Muir
