1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Multiple IOC
To: Jeff Hill <[email protected]>
Cc: [email protected]
Date: Tue, 04 Dec 2007 14:42:48 -0800
Jeff,
This worked. It did not seem to matter if I set the EPICS_CAS_SERVER_PORT = 5071 or not. It worked either way.
I did get errors on both IOC's though. They were basically the same whether I configured the EPICS_CAS_SERVER_PORT
Errors for IOC on default Port
pics> CAS: request from 128.95.181.18:33089 => "invalid (damaged?) request code from UDP"
CAS: Request from 128.95.181.18:33089 => cmmd=13 cid=0xa type=11 count=5071 postsize=0
CAS: Request from 128.95.181.18:33089 => available=0x805fb512 N=0 paddr=(nil)
CAS: invalid (damaged?) UDP request from 128.95.181.18:33089 ?
Errors for IOC's on Port 5071
epics> CAS: request from 128.95.181.18:33092 => "invalid (damaged?) request code from UDP"
CAS: Request from 128.95.181.18:33092 => cmmd=13 cid=0xa type=11 count=5064 postsize=0
CAS: Request from 128.95.181.18:33092 => available=0x805fb512 N=0 paddr=(nil)
CAS: invalid (damaged?) UDP request from 128.95.181.18:33092 ?
I also tried Andrews suggestion of not changing the port numbers on either IOC but then my edm screen would reconnect to one but not both IOC's if it became disconnected.
My intention is to be able to modularize my control processes to aid in troubleshooting and to have the flexibility to spread out processing if needed by moving IOC's between hardware. Is there a better way of doing this?
Thanks
Jeff Hill wrote:
For the IOC operating on the default port set...
EPICS_CA_ADDR_LIST=nnn.nnn.nnn.nnn:5071
For the IOC operating on 5071 port set...
EPICS_CA_ADDR_LIST=nnn.nnn.nnn.nnn:5064
-----Original Message-----
On Behalf Of Robert Emery
Sent: Tuesday, December 04, 2007 12:47 PM
To: [email protected]
Subject: Multiple IOC
I have two IOC's running on one linux PC.  One is using the default
ports and I changed the other's port using:
EPICS_CA_REPEATER_PORT=5070
EPICS_CA_SERVER_PORT=5071
I have been able to get an edm screen to see pv's from both IOC's by
changing the environment variable:
EPICS_CA_ADDR_LIST=nnn.nnn.nnn.nnn nnn.nnn.nnn.nnn:5071
I have not been able to get the two IOC's to see each others PV's. Any ideas how I would be able to do this?
Thanks
Rob Emery
UW Medical Center
RE: Multiple IOC Jeff Hill
Multiple IOC Robert Emery
Prev: Re: Java CA context cleanup issues on Linux? Kay-Uwe Kasemir
Next: Re: Java CA context cleanup issues on Linux? J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Multiple IOC Jeff Hill
Next: RE: Multiple IOC Jeff Hill
