1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Multiple IOC
To: "'Robert Emery'" <[email protected]>
Cc: [email protected]
Date: Wed, 5 Dec 2007 08:57:46 -0700
Robert,
> Request from 128.95.181.18:33089 => cmmd=13
>From here (based on cmmd=13) it appears that you might have it configured so
that the UDP beacon protocol is being sent to a CA server's UDP port (to a
CA PV name directory server).
Have a look in the manual at EPICS_CAS_BEACON_PORT (which defaults to
EPICS_CA_REPEATER_PORT).
Jeff
> -----Original Message-----
> From: Robert Emery [mailto:[email protected]]
> Sent: Tuesday, December 04, 2007 3:43 PM
> To: Jeff Hill
> Subject: Re: Multiple IOC
> Jeff,
> This worked.  It did not seem to matter if I set the
> EPICS_CAS_SERVER_PORT = 5071 or not.  It worked either way.
> I did get errors on both IOC's though.  They were basically the same
> whether I configured the EPICS_CAS_SERVER_PORT
> Errors for IOC on default Port
> pics> CAS: request from 128.95.181.18:33089 => "invalid
> (damaged?) request code from UDP"
> CAS: Request from 128.95.181.18:33089 => cmmd=13 cid=0xa type=11
> count=5071 postsize=0
> CAS: Request from 128.95.181.18:33089 =>  available=0x805fb512
> N=0 paddr=(nil)
> CAS: invalid (damaged?) UDP request from 128.95.181.18:33089 ?
> Errors for IOC's on Port 5071
> epics> CAS: request from 128.95.181.18:33092 => "invalid
> CAS: Request from 128.95.181.18:33092 => cmmd=13 cid=0xa type=11
> count=5064 postsize=0
> CAS: Request from 128.95.181.18:33092 =>  available=0x805fb512
> N=0 paddr=(nil)
> CAS: invalid (damaged?) UDP request from 128.95.181.18:33092 ?
> I also tried Andrews suggestion of not changing the port numbers on
> either IOC but then my edm screen would reconnect to one but not both
> IOC's if it became disconnected.
> My intention is to be able to modularize my control processes to aid in
> troubleshooting and to have the flexibility to spread out processing if
> needed by moving IOC's between hardware.  Is there a better way of doing
> this?
> Thanks
> Jeff Hill wrote:
> > For the IOC operating on the default port set...
> > EPICS_CA_ADDR_LIST=nnn.nnn.nnn.nnn:5071
> > For the IOC operating on 5071 port set...
> > EPICS_CA_ADDR_LIST=nnn.nnn.nnn.nnn:5064
> >> From: [email protected] [mailto:tech-talk-
> [email protected]]
> >> On Behalf Of Robert Emery
> >> Sent: Tuesday, December 04, 2007 12:47 PM
> >> To: [email protected]
> >> Subject: Multiple IOC
> >> I have two IOC's running on one linux PC.  One is using the default
> >> ports and I changed the other's port using:
> >> EPICS_CA_REPEATER_PORT=5070
> >> EPICS_CA_SERVER_PORT=5071
> >> I have been able to get an edm screen to see pv's from both IOC's by
> >> changing the environment variable:
> >> EPICS_CA_ADDR_LIST=nnn.nnn.nnn.nnn nnn.nnn.nnn.nnn:5071
> >> I have not been able to get the two IOC's to see each others PV's.  Any
> >> ideas how I would be able to do this?
> >> Thanks
> >> Rob Emery
> >> UW Medical Center
Re: Multiple IOC Robert Emery
RE: Multiple IOC Jeff Hill
Prev: RE: string monitoring in medm Jeff Hill
Next: Re: Cryocon and TSI hardware support? David Maden
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Multiple IOC Robert Emery
Next: Re: Multiple IOC Robert Emery
