1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Cryocon and TSI hardware support?
To: Steve Lewis <[email protected]>, [email protected]
Date: Wed, 05 Dec 2007 16:58:26 +0100
It seems as though our Web police don't allow access to our CVS repository. So I've put a tar-ball at:
www.sls.psi.ch/controls/help/howto/LakeshoreCryojet.tgz
which I'm told is accessible. It probably won't stay there very long, though.
David
Steve Lewis wrote:
I also need support for the Lakeshoe 340. The URL you gave does appear to be blocked. Perhaps you could make it available some other way. Much thanks in advance!
Shepherd, EL (Emma) wrote:
Hi all,
Has anyone written any EPICS support for a temperature controller or
temperature monitor made by Cryogenic Control Systems
(http://www.cryocon.com/)?
I'm also looking for support for a helium depth indicator made by
Twickenham Scientific Instruments (http://www.twicksci.co.uk/)
They all have serial interfaces so I am thinking about writing EPICS
support using Streams if nobody has done this already.
Cheers,
Emma
Hi Emma,
We don't have this particular temperature controller in our collection of serial devices at SLS, but we do have the Lakeshore models 331 and 340. Unless the PSI firewalls are blocking access, the CVS repository of the software should be visible here:
www.sls.psi.ch/cgi-bin/cvsweb.cgi/G/DRV/lakeshore/
We also have support for Oxford Instrument's cryojet with liquid nitrogen auto fill controller (same URL, substitute "cryojet" for "lakeshore"). They both have the same structure: a collection of simple stream-device EPICS records for sending commands and status requests to the device, glued together with an snl program. There's a bit of documentation on setting up the cryojet at:
www.sls.psi.ch/controls/help/howto/cryojet.html
but unfortunately nothing for the Lakeshore controllers.
Getting the Cryogenic Control Systems device to work with the Lakeshore code might simply be a case of a new stream-device protocol file.
For the helium depth indicator, you might consider simply connecting its analogue output to an ADC channel, rather than using its serial port.
Regards, David
Cryocon and TSI hardware support? Shepherd, EL (Emma)
Re: Cryocon and TSI hardware support? David Maden
Prev: RE: Multiple IOC Jeff Hill
Next: Stream protocol configuration Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Cryocon and TSI hardware support? David Maden
Next: A patch for medm Kate Feng
