1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: string monitoring in medm
To: "'Heinrich du Toit'" <[email protected]>, <[email protected]>
Date: Wed, 5 Dec 2007 08:48:27 -0700
Yes, this is a limitation of CA. A new variable length string type should be
placed on the list.
Jeff
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Heinrich du Toit
> Sent: Wednesday, December 05, 2007 2:26 AM
> To: [email protected]
> Subject: Re: string monitoring in medm
> Aint this another one of those nasty limits in Channel Access?
> Do you really need it as 1 long string?
> How about splitting it up into multiple smaller strings?
> -Heinrich
> Umashankar Panda wrote:
> > Dear Sirs,
> > I am usuing medm as the user interface. I have some async record in
> > string format whose character size is more than 40. I am getting the
> > value in precord after modifying the base code for handling strings
> > upto 80 characters. But, now my problem is that this data is not
> > getting fully displayed in medm. The size is limited upto 40 in medm.
> > This also happens in probe too.
> > Can anybody please suggest a solution for this problem?
> > Ultimately, I need to display the strings in a message box with
> > srcolling facility also. The data is the status of the helium
> > liquefier printed in ASCII format through a serial port.
> > Thanking you
> > With regards
> > Umashankar Panda
> > Variable Energy Cyclotron Centre
> > India.
string monitoring in medm Umashankar Panda
Re: string monitoring in medm Heinrich du Toit
Prev: Re: device support for output connected to volatile device John Dobbins
Next: RE: Multiple IOC Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: string monitoring in medm Heinrich du Toit
Next: Re: string monitoring in medm nda
