1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS in Debian 4.0 Linux
To: Umashankar Panda <[email protected]>
Cc: [email protected]
Date: Fri, 07 Dec 2007 06:37:23 +0100
Umashankar Panda schrieb:
Dear All,
I am trying to use EPICS in Debian 4.0 latest release. But I am unable
to build the base itself.  I feel some more packages are to be
installed.
I am requesting those who have used EPICS on Debian based linux to
tell me what are the extra packages I should load for running epics
base, medm, probe, channel archiver etc. on Debian 4.0 Linux.
I can't remember that any package was missing while building EPICS base, but for the extensions (esp. the Motif-applications) you definitely need a Motif-library. I strongly suggest to install the "original" Open Motif packages (libmotif3 and libmotiv-dev) instead of the lesstif-packages. Unfortunately the Open Motif packages are *not* available in Debian 4.0 (etch - the current "stable" distribution) and have to be installed from the current "testing" distribution.
The Channel Archiver brings an own set of source tar-balls of ThirdParty software-modules, that you as well should unpack, build and install to be used when building the ChannelArchiver.
Other than that, you may have encountered some perl-modules missing. We install these as soon as we encounter any perl-error-message like (Can't locate XYZ.pm in @INC (@INC contains: ...).
I unfortunately don't have a list of packages at hand right now, but I'll add a list of modules we additoinally install on our development and our production systems later.
Additionally, some Error-Messages from the build-process or from running the EPICS-applications will sure help to identify the missing packages. Feel free, to send me these messages and I might remember/be able to look up what we did here at BESSY.
Thomas
___________________________________________________________________________
Thomas Birke
BESSY GmbH
Albert-Einstein-Str. 15, D-12489 BERLIN
BESSY GmbH - Mitglied der Leibniz Gemeinschaft
Vorsitzender des Aufsichtsrates: Prof. Dr. Dr. h.c. mult Joachim Treusch
Geschäftsführer: Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Prof. Dr.
Eberhard Jaeschke Sitz Berlin, AG Charlottenburg, HRB 14635
EPICS in Debian 4.0 Linux Umashankar Panda
Prev: EPICS in Debian 4.0 Linux Umashankar Panda
Next: Re: EPICS in Debian 4.0 Linux Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
