1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Gateway questions
To: "Jeff Hill" <[email protected]>, <[email protected]>
Date: Tue, 11 Dec 2007 16:56:46 -0000
Title: Message
I am running the gateway on 3.14.8.2 so this I think this could explain the problem.
Thanks
Pete
-----Original Message-----
Sent: 11 December 2007 16:40
To: Leicester, PJ (Pete); [email protected]
Pete,
Ø  ../../../../src/cas/io/bsdSocket/casDGIntfIO.cc: CA beacon socket disconnect error was
Ø  "Network is unreachable"
This is possibly related to changes surrounding Mantis 217 and 246. What version of base is your gateway linked with? It appears that Mantis 246 might  be fixing your benign message in EPICS R3.14.9.
Jeff
From: [email protected] [mailto:[email protected]] On Behalf Of Leicester, PJ (Pete)
Sent: Tuesday, December 11, 2007 8:51 AM
To: [email protected]
Subject: Gateway questions
A have a few gateway question:-
1) We have just configured a couple of new gateways. When we first ran them they repeatedly wrote the following error message to the gateway log file every 15 seconds even though the gateway appeared to be working OK.
../../../../src/cas/io/bsdSocket/casDGIntfIO.cc: CA beacon socket disconnect error was "Network is unreachable"
Dec 11 12:02:34 !!! Errlog message received (message is above)
After some experimentation we found we could get rid of the error by adding a 'default' route to the routing tables on the host machine. We actually set up a default route to a non-existent IP address.
Is this a problem with the gateway software or have we missed something in our gateway configuration? (We are running gateway version 2.0.0.0)
2) I notice that a '-archive' option has appeared in the latest gateway. We currently run a separate additional gateway exclusively for our archiver with the '-mask l' option to ensure we don't archive anything based on MDEL (a parallel gateway serves PV's to edm and other clients). What is the difference between '-archive' and '-mask l'? Should I now revert to having a single 'gateway -archive' for both the archiver and other (edm) clients? Would I gain/lose anything?
3) Where do I find a summary of the changes between gateway version 2.0.0.0 and the two later versions 2.0.2.0 and 2.0.2.1?
Pete
Pete  Leicester
Senior Software Engineer
Diamond Light Source Ltd.
RE: Gateway questions Jeff Hill
Prev: RE: Gateway questions Jeff Hill
Next: how to stop ca monitor Zhong Ren
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
