Title: Message
Pete,
Ø ../../../../src/cas/io/bsdSocket/casDGIntfIO.cc:
CA beacon socket disconnect error was
Ø "Network is unreachable"
This is possibly related to changes
surrounding Mantis 217 and 246. What version of base is your gateway linked
with? It appears that Mantis 246 might be fixing your benign message in EPICS
R3.14.9.
Jeff
A have
a few gateway question:-
1)
We have just configured a couple of new gateways. When we first ran them they
repeatedly wrote the following error message to the gateway log file every 15
seconds even though the gateway appeared to be working OK.
CA beacon socket disconnect error was "Network is unreachable"
Dec
11 12:02:34 !!! Errlog message received (message is above)
After
some experimentation we found we could get rid of the error by adding a
'default' route to the routing tables on the host machine. We actually set up a
default route to a non-existent IP address.
Is
this a problem with the gateway software or have we missed something in our
gateway configuration? (We are running gateway version 2.0.0.0)
2)
I notice that a '-archive' option has appeared in the latest gateway. We
currently run a separate additional gateway exclusively
for our archiver with the '-mask l' option to ensure we don't archive
anything based on MDEL (a parallel gateway serves PV's to edm and other
clients). What is the difference between '-archive' and '-mask l'? Should I now
revert to having a single 'gateway -archive' for both the
archiver and other (edm) clients? Would I gain/lose anything?
3)
Where do I find a summary of the changes between gateway version 2.0.0.0 and
the two later versions 2.0.2.0 and 2.0.2.1?
Pete
Leicester
Senior
Software Engineer
Diamond
Light Source Ltd.
This e-mail and any
attachments may contain confidential, copyright and or privileged material, and
are for the use of the intended addressee only. If you are not the intended
addressee or an authorised recipient of the addressee please notify us of receipt
by returning the e-mail and do not use, copy, retain, distribute or disclose
the information in or attached to the e-mail.
Any opinions expressed within this e-mail are those of the individual and not
necessarily of Diamond Light Source Ltd.
Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments
are free from viruses and we cannot accept liability for any damage which you
may sustain as a result of software viruses which may be transmitted in or with
the message.
Diamond Light Source Limited (company no. 4375679). Registered in England and
Wales with its registered office at Diamond House, Harwell Science and
Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
- RE: Gateway questions Leicester, PJ (Pete)
- Gateway questions Leicester, PJ (Pete)
Re: Gateway questions Ralph Lange
<2007>
2025
2026
<2007>
2025
2026
ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
