A have a few gateway
question:-
1) We have just configured
a couple of new gateways. When we first ran them they repeatedly wrote the
following error message to the gateway log file every 15 seconds even though the gateway appeared to be
working OK.
../../../../src/cas/io/bsdSocket/casDGIntfIO.cc: CA beacon
socket disconnect error was "Network is unreachable"
Dec 11 12:02:34 !!! Errlog message received (message is
above)
After
some experimentation we found we could get rid of the error by adding a
'default' route to the routing tables on the host machine. We actually set up a
default route to a non-existent IP address.
Is
this a problem with the gateway software or have we missed something in our
gateway configuration? (We are running gateway version
2.0.0.0)
2) I notice that a
'-archive' option has appeared in the latest gateway. We currently run a
separate additional gateway exclusively for our archiver with the
'-mask l' option to ensure we don't archive anything based on MDEL (a parallel
gateway serves PV's to edm and other clients). What is the difference between
'-archive' and '-mask l'? Should I now revert to having a single 'gateway -archive' for both the archiver and other (edm) clients? Would I gain/lose anything?
3) Where do I find a summary of the changes between gateway version
2.0.0.0 and the two later versions 2.0.2.0 and
2.0.2.1?
Pete
Pete Leicester
Senior Software Engineer
Diamond Light Source
Ltd.
Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd. Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message. Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
| ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
