1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Gateway questions
To: "Leicester, PJ \(Pete\)" <[email protected]>
Cc: [email protected]
Date: Tue, 11 Dec 2007 17:25:56 +0100
Hello Pete,
Leicester, PJ (Pete) wrote:
A have a few gateway question:-
1) We have just configured a couple of new gateways. When we first ran them they repeatedly wrote the following error message to the gateway log file every 15 seconds even though the gateway appeared to be working OK.
../../../../src/cas/io/bsdSocket/casDGIntfIO.cc: CA beacon socket disconnect error was "Network is unreachable"
Dec 11 12:02:34 !!! Errlog message received (message is above)
After some experimentation we found we could get rid of the error by adding a 'default' route to the routing tables on the host machine. We actually set up a default route to a non-existent IP address.
Is this a problem with the gateway software or have we missed something in our gateway configuration? (We are running gateway version 2.0.0.0)
I've never seen this message - looks to me as if the server side of the Gateway is not able to send UDP broadcasts (beacons). That would probably make it a network configuration issue of the host machine rather than a Gateway software or configuration problem.
But I better leave this for Jeff to answer.
2) I notice that a '-archive' option has appeared in the latest gateway. We currently run a separate additional gateway exclusively for our archiver with the '-mask l' option to ensure we don't archive anything based on MDEL (a parallel gateway serves PV's to edm and other clients). What is the difference between '-archive' and '-mask l'? Should I now revert to having a single 'gateway -archive' for both the archiver and other (edm) clients? Would I gain/lose anything?
We did make this transition recently - there should not be a noticeable functional difference.
The '-mask' options sets the flags for all client connections of the Gateway, the '-archive' flag tells the Gateway to open a second client connection using the archive flag as soon as a client connects that uses the archive flag. So, '-archive' does more or less automatically what you've been doing manually so far.
In both cases will regular clients get the regular (MDEL based) updates, while archiver clients will get the archive (ADEL based) events.
The only difference I can see right now:
With an existing regular (archive) connection, the first archiver (regular) client connecting to the same channel would issue a new name resolution broadcast on the client side and open a new tcp connection in the two-process layout, while the single process would not broadcast the name and only set up a new event subscription using the existing tcp connection (as it already is connected to the channel).
3) Where do I find a summary of the changes between gateway version 2.0.0.0 and the two later versions 2.0.2.0 and 2.0.2.1?
Dirk's slides of the April 2007 EPICS meeting at DESY (ftp://ftp.desy.de/pub/EPICS/meeting-2007/ChannelAccessGatewayUpdate.pdf) should cover the main changes.
Hope this helps,
Ralph
Gateway questions Leicester, PJ (Pete)
Prev: Gateway questions Leicester, PJ (Pete)
Next: RE: Gateway questions Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
