1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: build snl program
To: Janet Anderson <[email protected]>
Cc: [email protected]
Date: Thu, 3 Jan 2008 08:39:58 +0800
cIOC1PScontrol.st is in the same directory as the file Makefile, and I set the
variable
SNCSEQ=/home/rtems/base3.14.6/base/src/sequence
in the file base/configure/REALEASE, but after make, the error still appears.
can you provide some details when you install SNC and set enrionment variable?
Thanks!
Haoli Shi
Re: build snl program Emmanuel Mayssat
Prev: Re: Help with udev Emmanuel Mayssat
Next: Re: build snl program Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Ca error Jeff Hill
