It seems that your makefile doesn't know how to compile the st snl
program. It is probably because it cannot find the SEQ
binaries/libraries.
Did you remember to run "make" in the configure directory after changing
the RELEASE file? I always found this step counter intuitive...
BTW, is SNCSEQ set correctly? Shouldn't the sequencer be installed
outside of the base tree, let's say
in /home/rtems/epics-extras-3.14.6/seq-2.11 ?
Emmanuel
On Thu, 2008-01-03 at 08:39 +0800, åæç wrote:
> cIOC1PScontrol.st is in the same directory as the file Makefile, and I set the
> variable
> SNCSEQ=/home/rtems/base3.14.6/base/src/sequence
> in the file base/configure/REALEASE, but after make, the error still appears.
> can you provide some details when you install SNC and set enrionment variable?
> Thanks!
> Haoli Shi
- Re: build snl program 师昊礼
problem in running application of PSM6003 zhangdemin99
<2008>
2025
2026
<2008>
2025
2026
