Hi Chris
The reason for this is that gateway no longer posts events with log
event mask if 'archive' option is not used.
I can see that this can be interpreted as wrong behavior. It could be
changed in a way that if 'archive' option is not used the gateway
should posts all events with value/log mask which means that archiver
would get all value changes dictated by MDEL and ADEL would be ignored.
Best Regards
Gasper
Chris Timossi wrote:
I'm using the latest version of the gateway with EPICS base 3.14.9
together with the Channel Archiver as a client. I'm curious why the
Archiver records so much less data through the gateway than it does
archiving the IOC data directly. I'd expect some difference, but it
seems like the Archiver hardly sees any value-change events through
the GW.
I'm looking at about 1000 PVs with the MDELs set such that events
should be coming in at a high rate; in fact, the GW clientEventRate is
5000hz. But the archiver is missing almost all the value changes
(though it does seem to catch severity changes). I'm using the
'no_cache' option but it doesnt make any difference.
I'm purposely not using the 'archive' option. I dont remember the
older CA GW behaving this way.
Chris Timossi
Advanced Light Source
Lawrence Berkeley Laboratory
- Re: gateway throttling events? Janet Anderson
Alarm Handler on 64-bit Peter Medvescek
multiple levels of substitution in msi John Dobbins
<2008>
2025
2026
<2008>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
