1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: gateway throttling events?
To: Gasper Jansa <[email protected]>
Cc: Chris Timossi <[email protected]>, epics <[email protected]>
Date: Tue, 15 Jan 2008 11:10:25 -0600
A new gateway release, Gateway2-0-3-0, restoring the old gateway default behavior is now available.
Now if "-archive" is not used gateway will post log events along with value change events.
Janet
Gasper Jansa wrote:
Hi Chris
The reason for this is that gateway no longer posts events with log event mask if 'archive' option is not used.
I can see that this can be interpreted as wrong behavior. It could be changed in a way that if 'archive' option is not used the gateway should posts all events with value/log mask which means that archiver would get all value changes dictated by MDEL and ADEL would be ignored.
Best Regards
Gasper
Chris Timossi wrote:
I'm using the latest version of the gateway with EPICS base 3.14.9 together with the Channel Archiver as a client. I'm curious why the Archiver records so much less data through the gateway than it does archiving the IOC data directly. I'd expect some difference, but it seems like the Archiver hardly sees any value-change events through the GW.
I'm looking at about 1000 PVs with the MDELs set such that events should be coming in at a high rate; in fact, the GW clientEventRate is 5000hz. But the archiver is missing almost all the value changes (though it does seem to catch severity changes). I'm using the 'no_cache' option but it doesnt make any difference.
I'm purposely not using the 'archive' option. I dont remember the older CA GW behaving this way.
Chris Timossi
Advanced Light Source
Lawrence Berkeley Laboratory
Re: gateway throttling events? Gasper Jansa
Prev: Re: erro when writing to the GPIB device on softIOC Emmanuel Mayssat
Next: Re: VXI11 GPIB and asynRecord Eric Williams
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: gateway throttling events? Gasper Jansa
Next: multiple levels of substitution in msi John Dobbins
