1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: erro when writing to the GPIB device on softIOC
To: zhangdemin99 <[email protected]>
Cc: [email protected]
Date: Mon, 14 Jan 2008 09:35:40 -0800
Hello,
The first thing that come to mind is that asyn doesn't pass the reply to
devGpib. You may have to review your terminator settings.
Did you set the input and output terminators at the asyn as well as at
the devGpib level?
You may want to try to attach an asynRecord to the interface and
communicate with it directly. Doing so, you will bypass devGpib.
Before you jump into devGpib, you may want to have a look at
streamDevice.
E
On Mon, 2008-01-14 at 16:29 +0800, zhangdemin99 wrote:
> Dera all,
>  I am trying to communicate with the GPIB device on the softIOC with
> GPIB bus.
> When I write to the device:
> epics> dbpf PSM6003:PSM6003Record:current-step 0.5
> DBR_STRING:          0.5
> it appears erro information after a few seconds:
> epics> 2008/01/14 10:51:45.364 L0 addr 0 : device timed out.
> 2008/01/14 10:51:45.365 PSM6003:PSM6003Record:current-step write
> status "L0 writeGpib failed EABO 6: Operation aborted
> " requested 19 but sent 5211728 bytes
> 2008/01/14 10:51:45.365 PSM6003:PSM6003Record:current-step error.
> 2008/01/14 10:52:15.362 L0 addr 0 : device timed out.
> 2008/01/14 10:52:15.362 PSM6003:PSM6003Record:current-step
> respond2Writes read failed
> Why it says device timed out. I am sure the device and the PCI-GPIB
> card are
> connected well. "requested 19 but sent 5211728 bytes", should I clean
> the buffer, how to?
> The command array I set are:
>  {&DSET_SO,GPIBWRITE,IB_Q_LOW,NULL,":CURRent:STEP %
> S",50,50,NULL,0,0,NULL,NULL,NULL},
>     {&DSET_SI,GPIBREAD,IB_Q_LOW,":CURRent:STEP?","%39[^\r
> \n]",0,50,NULL,0,0,NULL,NULL,NULL}
> many thanks in advance
> ______________________________________________________________________
> ç æ æ é è å ïï å ç æ å å ç å è è æ ä è è å ï å
> æ 2 å ï
Re: erro when writing to the GPIB device on softIOC Stefan Heim
erro when writing to the GPIB device on softIOC zhangdemin99
Prev: 2008 EPICS meeting website SQLiu
Next: Re: gateway throttling events? Janet Anderson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: erro when writing to the GPIB device on softIOC zhangdemin99
Next: Re: erro when writing to the GPIB device on softIOC Stefan Heim
