1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: error in communicating to the GPIB device with NI-PCI board
To: tech-talk <[email protected]>
Date: Fri, 18 Jan 2008 18:14:58 +0800 (CST)
Dear all,
  I am trying to communicate the GPIB device with a NI-PCI board.
I have built base-3.14.9,StreamaDevice-2-3,asyn4-7 with LINUX_GPIB=yes
,linux-gpib-3.2.09
and the  board driver NI-488.2-beta-2.5.1b0 on the RHEL4.
  When I run the application, there are always errors.especially
"Command GpibBoardDriverConfig not found".
[fel@localhost iocPSM6003]$ ../../bin/linux-x86/PSM6003 st.cmd
#!../../bin/linux-x86/PSM6003
## You may have to change PSM6003 to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet(ARCH,"linux-x86")
epicsEnvSet(IOC,"iocPSM6003")
epicsEnvSet(TOP,"/home/fel/psm6003/psm6003")
epicsEnvSet(PSM6003,"/home/fel/psm6003/module/psm6003")
epicsEnvSet(ASYN,"/home/fel/psm6003/asyn4-7")
epicsEnvSet(EPICS_BASE,"/home/fel/psm6003/base")
epicsEnvSet ("STREAM_PROTOCOL_PATH", "../../PSM6003APP/Db:.")
dbLoadDatabase("../../dbd/PSM6003.dbd",0,0)
PSM6003_registerRecordDeviceDriver(pdbbase)
## Load record instances
dbLoadRecords("../../db/devPSM6003.db","P=PSM6003:,R=,L=0,A=0")
GpibBoardDriverConfig("L0",1,0,3,0)
st.cmd -- Line 15 -- Command GpibBoardDriverConfig not found.
iocInit()
Starting iocInit
## EPICS R3.14.9 $R3-14-9$ $2007/02/05 16:31:45$
## EPICS Base built Jan 17 2008
2008/01/18 17:13:41.457 Businterface 'L0' not found for 'query-current'
2008/01/18 17:13:41.458 query-current: Can't attach to bus L0 0
2008/01/18 17:13:41.458 query-current: Record initialization failed
2008/01/18 17:13:41.458 Businterface 'L0' not found for 'setcurrent'
2008/01/18 17:13:41.458 setcurrent: Can't attach to bus L0 0
2008/01/18 17:13:41.458 setcurrent: Record initialization failed
iocInit: All initialization complete
## Start any sequence programs
#seq sncPSM6003,"user=fel"
The CA server's beacon address list was empty after initialization?
epics>
many thanks in advance
LOGO 又过年了,千万别忘了把你的爱带回家
为爱珍选,唯有金典
Re: error in communicating to the GPIB device with NI-PCI board Stefan Heim
Prev: RE: CA connection management problem Owens, PH (Peter)
Next: Re: error in communicating to the GPIB device with NI-PCI board Stefan Heim
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: CA connection management problem Jeff Hill
