1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CA connection management problem
To: <[email protected]>
Date: Fri, 18 Jan 2008 09:39:03 -0000
> Please delete the "goto START" line from inside the for()
> loop and try
> again; the program should not be recreating its CA context
> just because
You cannot just set up the channel and then loop on a
      ca_get ;
	ca_pend_io
That was my first attempt.
When you restart EPICS you get the message
ca_get failed Virtual circuit disconnect
forever.
So I tried to tidy up and recreate the channel but it seems that the
fatal error is in ca_context_destroy.
Vic
Re: CA connection management problem Andrew Johnson
CA connection management - vxWorks David Maden
Prev: Re: erro when writing to the GPIB device on softIOC Stefan Heim
Next: error in communicating to the GPIB device with NI-PCI board zhangdemin99
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CA connection management problem Maren Purves
Next: Re: CA connection management problem Andrew Johnson
