1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CA connection management - vxWorks
To: [email protected]
Date: Tue, 22 Jan 2008 09:16:08 +0100
I also have a CA connection management problem similar to the recent thread:
         Re: CA connection management problem
but hopefully different enough to warrant a slightly different name.
I'm trying to convert a vxWorks channel access C program from EPICS 3.13.10 to 3.14.8. The program is intended to run once after iocInit and then exit. I get an exception in ca_context_destroy if the channel connection times out.
Reducing the program to its bare essentials, it does the following:
1) Set up ca context with preemptive callbacks enabled:
ca_context_create (ca_enable_preemptive_callback)
2) Call ca_create_channel specifying channel name and callback function.
  3) Wait for callback function to get called:
       If callback function is called, goto step 5.
       If there is a time-out, go to step 4.
4) On time-out, call ca_context_destroy and return with error.
  5) If callback function gets called, continue with calls
     to ca_get, ca_pend_io, ca_context_destroy and return with success.
This runs fine if I specify a PV which is valid.
If I specify an invalid channel name, I get:
    0x15d0250 (tShell): Unhandled C++ exception resulted
                        in call to terminate
The program runs fine under Linux. Is there some problem with ca_context_destroy under vxWorks, which I couldn't find in the Channel Access Reference Manuel or the tech-talk archives? I note, for example, that snl programs under 3.14 are no longer able to exit. Is this related?
Regards, David
[email protected]
SLS Project
RE: CA connection management - vxWorks Jeff Hill
RE: CA connection management problem Owens, PH (Peter)
Prev: Re: error in communicating to the GPIB device with NI-PCI board Stefan Heim
Next: RE: CA connection management - vxWorks Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CA connection management problem Andrew Johnson
