1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA connection management problem
To: [email protected]
Date: Thu, 17 Jan 2008 08:54:34 -1000
Andrew Johnson wrote:
Owens, PH (Peter) wrote:
-----Original Message----- From: Victor F E Pucknell [mailto:[email protected]]
Here is a simple test using the EPICS caget
Normally it is in a loop using caget every 2 seconds.
If you "quit" the EPICS server then I get a serious failure and the test program is lost somewhere in the ca library
Please delete the "goto START" line from inside the for() loop and try again; the program should not be recreating its CA context just because a channel has disconnected. The CA client library handles disconnection and reconnections itself internally, and by recreating the context every time there's a timeout error you're almost certainly confusing it.
Also, I would think if you do this too many times you're going to get too many connections and your IOC will become unresponsive to the outside world (part of this quite possibly being caused by memory fragmentation. We have one IOC that does that on occasion.).
Maren, UKIRT.
CA connection management problem Owens, PH (Peter)
Re: CA connection management problem Andrew Johnson
Prev: RE: CA connection management problem Jeff Hill
Next: Re: erro when writing to the GPIB device on softIOC Stefan Heim
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CA connection management problem Andrew Johnson
Next: RE: CA connection management problem Owens, PH (Peter)
