1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asynRecord immutable fields
To: "Eric Williams" <[email protected]>, <[email protected]>
Date: Tue, 22 Jan 2008 20:43:30 -0600
Those fields are definitely writeable from EPICS channel access.  Have you tested that?
I can't say that I've ever tried linking to them with database links, but I can't see why it would not work.
Sent: Tue 1/22/2008 7:40 PM
To: [email protected]
Subject: asynRecord immutable fields
I'm trying to drive a GPIB device with a genSub record through an
asynRecord, but I've been unable to change some of the asynRecord fields
that I need to perform all the necessary control functions.
In particular, I've been unable to modify TMOD or NOWT, which I've
linked to output fields of the genSub record.  (There are probably other
asynRecord fields that act similarly, but these are the ones I've run
into so far.)  Writing to AOUT works OK.
If I link my genSub record output fields instead to "normal" records
(eg: longout), then the values go through just fine.  But they never
show up when linked to the asynRecord fields.  In contrast, I'm able to
modify these fields through dbpf on the console.
I've looked at the DBD file, and I'm not able to find any reason why one
field would be writable and another isn't.  Anybody have a guess?
eric
Environment:
    linux-x86
    epics 3.14.9
    asyn 4-8
    genSub 4-6
Re: asynRecord immutable fields Eric Williams
Prev: asynRecord immutable fields Eric Williams
Next: Re: CA connection management - vxWorks David Maden
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: asynRecord immutable fields Eric Williams
