In particular, I've been unable to modify TMOD or NOWT, which I've linked to output fields of the genSub record. (There are probably other asynRecord fields that act similarly, but these are the ones I've run into so far.) Writing to AOUT works OK. If I link my genSub record output fields instead to "normal" records (eg: longout), then the values go through just fine. But they never show up when linked to the asynRecord fields. In contrast, I'm able to modify these fields through dbpf on the console. I've looked at the DBD file, and I'm not able to find any reason why one field would be writable and another isn't. Anybody have a guess? -- eric Environment: linux-x86 epics 3.14.9 asyn 4-8 genSub 4-6
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
