1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asynRecord immutable fields
Cc: [email protected]
Date: Wed, 23 Jan 2008 11:33:08 -0800
Sorry, I wasn't explicit enough.
I added 'CA' to the link specifier for the genSub output fields in the database file, but the NOWT and TMOD fields still won't change.
My IOC doesn't appear to have 'caput' available from the command line, but 'dbpf' works just fine to change those fields.
eric
Mark Rivers wrote:
Eric,
I didn't think of that, but I just tried it and the results are the same.
I am not sure what you my by "tried it" (using channel access?) and "the results are the same". The same as with the gensub record, or the same as I reported? Were you able to change the NOWT and TMOD fields from channel access?
I can defintely change them from channel access, using the caget and
caput commands on Linux:
corvette> caget 13LAB:serial1.TMOD
13LAB:serial1.TMOD Write/Read corvette> caput 13LAB:serial1.TMOD Read
Old : 13LAB:serial1.TMOD Write/Read New : 13LAB:serial1.TMOD Read corvette> caget 13LAB:serial1.TMOD
13LAB:serial1.TMOD Read corvette> caput 13LAB:serial1.TMOD "Write/Read"
Old : 13LAB:serial1.TMOD Read New : 13LAB:serial1.TMOD Write/Read corvette> caget 13LAB:serial1.TMOD
13LAB:serial1.TMOD Write/Read corvette> caget 13LAB:serial1.NOWT
13LAB:serial1.NOWT 80 corvette> caput 13LAB:serial1.NOWT 120
Old : 13LAB:serial1.NOWT 80 New : 13LAB:serial1.NOWT 120 corvette> caget 13LAB:serial1.NOWT
13LAB:serial1.NOWT 120 corvette> caput 13LAB:serial1.NOWT 80
Old : 13LAB:serial1.NOWT 120 New : 13LAB:serial1.NOWT 80 corvette> caget 13LAB:serial1.NOWT
Can you do this?
The TIME field of the asynRecord definitely shows the record is being processed when I try to write the field.
Which field?
-----Original Message-----
From: Eric Williams [mailto:[email protected]] Sent: Wednesday, January 23, 2008 12:25 PM
To: Mark Rivers
eric
Mark Rivers wrote:
Those fields are definitely writeable from EPICS channel
access. Have you tested that?
I can't say that I've ever tried linking to them with
database links, but I can't see why it would not work.
Sent: Tue 1/22/2008 7:40 PM
To: [email protected]
Subject: asynRecord immutable fields
I'm trying to drive a GPIB device with a genSub record through an
asynRecord, but I've been unable to change some of the
asynRecord fields
that I need to perform all the necessary control functions.
In particular, I've been unable to modify TMOD or NOWT, which I've
linked to output fields of the genSub record. (There are
probably other
asynRecord fields that act similarly, but these are the
ones I've run
into so far.) Writing to AOUT works OK.
If I link my genSub record output fields instead to "normal" records
(eg: longout), then the values go through just fine. But they never
show up when linked to the asynRecord fields. In contrast,
I'm able to
modify these fields through dbpf on the console.
I've looked at the DBD file, and I'm not able to find any
reason why one
field would be writable and another isn't.  Anybody have a guess?
eric
Environment:
    linux-x86
    epics 3.14.9
    asyn 4-8
    genSub 4-6
RE: asynRecord immutable fields Mark Rivers
Prev: RE: asynRecord immutable fields Mark Rivers
Next: RE: asynRecord immutable fields Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
