1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asynRecord immutable fields
To: "Eric Williams" <[email protected]>
Cc: [email protected]
Date: Wed, 23 Jan 2008 12:59:26 -0600
Eric,
> I didn't think of that, but I just tried it and the results
> are the same.
I am not sure what you my by "tried it" (using channel access?) and "the
results are the same".  The same as with the gensub record, or the same
as I reported?  Were you able to change the NOWT and TMOD fields from
channel access?
I can defintely change them from channel access, using the caget and
caput commands on Linux:
corvette> caget 13LAB:serial1.TMOD
13LAB:serial1.TMOD             Write/Read
corvette> caput 13LAB:serial1.TMOD Read
Old : 13LAB:serial1.TMOD             Write/Read
New : 13LAB:serial1.TMOD             Read
corvette> caput 13LAB:serial1.TMOD "Write/Read"
Old : 13LAB:serial1.TMOD             Read
New : 13LAB:serial1.TMOD             Write/Read
corvette> caget 13LAB:serial1.NOWT
13LAB:serial1.NOWT             80
corvette> caput 13LAB:serial1.NOWT 120
Old : 13LAB:serial1.NOWT             80
New : 13LAB:serial1.NOWT             120
corvette> caput 13LAB:serial1.NOWT 80
Old : 13LAB:serial1.NOWT             120
New : 13LAB:serial1.NOWT             80
Can you do this?
> The TIME field of the asynRecord definitely shows the record is being
> processed when I try to write the field.
Which field?
> -----Original Message-----
> From: Eric Williams [mailto:[email protected]]
> Sent: Wednesday, January 23, 2008 12:25 PM
> To: Mark Rivers
> Subject: Re: asynRecord immutable fields
> are the same.
> eric
> Mark Rivers wrote:
> > Those fields are definitely writeable from EPICS channel
> access.  Have you tested that?
> > I can't say that I've ever tried linking to them with
> database links, but I can't see why it would not work.
> > Mark
> > ________________________________
> > From: [email protected] on behalf of Eric Williams
> > Sent: Tue 1/22/2008 7:40 PM
> > To: [email protected]
> > Subject: asynRecord immutable fields
> > I'm trying to drive a GPIB device with a genSub record through an
> > asynRecord, but I've been unable to change some of the
> asynRecord fields
> > that I need to perform all the necessary control functions.
> > In particular, I've been unable to modify TMOD or NOWT, which I've
> > linked to output fields of the genSub record.  (There are
> probably other
> > asynRecord fields that act similarly, but these are the
> ones I've run
> > into so far.)  Writing to AOUT works OK.
> > If I link my genSub record output fields instead to "normal" records
> > (eg: longout), then the values go through just fine.  But they never
> > show up when linked to the asynRecord fields.  In contrast,
> I'm able to
> > modify these fields through dbpf on the console.
> > I've looked at the DBD file, and I'm not able to find any
> reason why one
> > field would be writable and another isn't.  Anybody have a guess?
> > eric
> > Environment:
> >     linux-x86
> >     epics 3.14.9
> >     asyn 4-8
> >     genSub 4-6
Re: asynRecord immutable fields Eric Williams
Prev: Re: asynRecord immutable fields Eric Williams
Next: Re: asynRecord immutable fields Eric Williams
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
