If the TIME field is changing when the gensub record processes, then
something is causing the asyn record to process.
I wonder if having the links for TMOD and NOWT =PP is causing your
problem. Perhaps when it goes to write those values the asyn record is
already processing (PACT=1) and so it won't write the values. Try
changing those links to NPP.
> -----Original Message-----
> From: Eric Williams [mailto:[email protected]]
> Sent: Wednesday, January 23, 2008 2:43 PM
> To: Mark Rivers
> Cc: [email protected]
> Subject: Re: asynRecord immutable fields
> Mark Rivers wrote:
> >> When I process the genSub record, which triggers
> >> the write to those fields, the TIME field of the asynRec
> is updated.
> > That is incorrect behavior, writing to the TMOD or NOWT
> fields should NOT cause the TIME field to update, because
> those fields are not defined as PP (Process Passive). When I
> test modifying those fields with dbpf the TIME field does NOT update:
> Since I didn't say TIME changed with dbpf, I'm not surprised at your
> results.
> > I suspect that perhaps you have the attribute PP on your
> gensub links for the TMOD and NOWT fields, while those should
> actually be NPP. But I still don't understand why the fields
> would not update.
> Yes, the links from the genSub record are PP. That may be
> unnecessary,
> but, as you say, it doesn't explain why the fields won't update. If
> there were a bug in my genSub processing routine, then when I re-link
> the output to a longin record instead of NOWT it should also
> fail. Yet
> it succeeds. Very puzzling.
- Re: asynRecord immutable fields Eric Williams
Re: subArray / waveform problem Rodney R. Porter
<2008>
2025
2026
subArray / waveform problem Shepherd, EL (Emma)
<2008>
2025
2026
