1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: asyn/stream reconnect problems
To: [email protected]
Date: Mon, 28 Jan 2008 11:42:30 +0100
Strange things happen here:
When I turn off and on again a GPIB gateway (E5810A) controlled via soft
IOC, asyn, and streamDevice, sometimes the connection is not
re-established. However, it reconnects as soon as I enable or disable asyn
debug messages a la
  asynSetTraceMask L3 20 0x0000
Here is a transcript that illustrates what happens:
epics> asynSetTraceMask L3 20 0x0010
[now I turn power off and on again]
epics> 2008/01/28 11:11:29.645 L3 vxi11 clientCall errno Success clnt_stat 5
L3 vxiWriteAddressed _? RPC error : RPC: Timed out
2008/01/28 11:11:29.645 L3 callback
2008/01/28 11:11:29.645 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:29.645 L3 schedule queueRequest timeout
2008/01/28 11:11:29.645 L3 20 vxiWrite numchars 17
2008/01/28 11:11:29.857 L3 asynManager:queueTimeoutCallback
2008/01/28 11:11:29.937 L3 asynManager:queueTimeoutCallback
2008/01/28 11:11:29.937 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:29.937 L3 schedule queueRequest timeout
2008/01/28 11:11:29.992 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:29.992 L3 schedule queueRequest timeout
2008/01/28 11:11:39.645 PAHRP:NRVD:rdPow(2): asynError in write: L3 RPC
failed
2008/01/28 11:11:39.645 PAHRP:NRVD:cmdGtl queueRequest
2008/01/28 11:11:39.645 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:39.645 L3 schedule queueRequest timeout
2008/01/28 11:11:39.645 L3 callback
2008/01/28 11:11:39.645 L3 20 vxiWrite numchars 17
2008/01/28 11:11:39.993 L3 asynManager:queueTimeoutCallback
2008/01/28 11:11:40.032 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:40.032 L3 schedule queueRequest timeout
2008/01/28 11:11:45.674 L3 vxiDestroyDevLink RPC error : RPC: Unable to
send;
errno = Broken pipe
2008/01/28 11:11:45.674 L3 vxiDisconnectPort : RPC: Unable to send; errno =
Broken pipe
2008/01/28 11:11:47.681 L3 vxiDestroyDevLink RPC error : RPC: Unable to
send;
errno = Broken pipe
L3 port not connected
2008/01/28 11:11:47.681 L3 asynGpib:pollAddr srqEnable
2008/01/28 11:11:47.681 PAHRP:NRVD:rdPow(1): asynError in write: L3 RPC
failed
2008/01/28 11:11:47.682 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:47.682 L3 schedule queueRequest timeout
2008/01/28 11:11:50.033 L3 asynManager:queueTimeoutCallback
2008/01/28 11:11:50.033 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:50.033 L3 schedule queueRequest timeout
2008/01/28 11:11:50.038 gpib0 vxiCreateDeviceLink abort channel TCP port
changed from 1002 to 1005
2008/01/28 11:11:50.096 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:50.096 L3 schedule queueRequest timeout
2008/01/28 11:11:57.681 L3 asynManager:queueTimeoutCallback
2008/01/28 11:12:00.033 L3 asynManager:queueTimeoutCallback
[The last few lines repeat endlessly; device stays INVALID/TIMEOUT; now I
do:]
2008/01/28 11:17:12.557 L3 addr 20 queueRequest priority 3 not lockHolder
2008/01/28 11:17:12.557 asynManager connect queueCallback port:L3
2008/01/28 11:17:12.557 L3 addr 20 vxiConnect
epics> 2008/01/28 11:17:12.559 gpib0,20 vxiCreateDeviceLink abort channel
TCP
port changed from 1002 to 1005
And suddenly connection is established again.
Is this a known problem? Is there a fix?
My setup: linux-x86, epicsBase3-14-8-2, asyn4-8, streamDevice2-2
Cheers
Ben
Re: asyn/stream reconnect problems Benjamin Franksen
RE: asyn/stream reconnect problems Mark Rivers
Prev: Re: subArray / waveform problem Rodney R. Porter
Next: Re: asyn/stream reconnect problems Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
