On Monday 28 January 2008 12:09, Benjamin Franksen wrote:
> On Monday 28 January 2008 11:42, Benjamin Franksen wrote:
> > Strange things happen here:
> Oh, never mind... I just see there is a new StreamDevice release that
> (according to the release notes) might have solved the problem. I'll try
> the new release and see what happens.
Too bad: I misread the release notes, the problem is /not/ solved. I
upgraded to asyn-4.9 and StreamDevice-2.3, still the same behaviour:
sometimes after a reset of the GPIB gateway, the IOC doesn't re-connect,
the records remain INVALID/TIMEOUT. As soon as I call any of the asyn
routines (even asynShowOption is enough) from the iocsh, the system
successfully reconnects. I think, as a stop-gap measure I will add a
subroutine record that periodically calls some asyn routine, preferably one
that produces no output and doesn't change the system's behaviour. (Any
hint which I could use?)
Cheers
Ben
- asyn/stream reconnect problems Benjamin Franksen
- Re: asyn/stream reconnect problems Benjamin Franksen
RE: asyn/stream reconnect problems Mark Rivers
<2008>
2025
2026
<2008>
2025
2026
