Hi Ben,
Please try to modify AsynDriverInterface.cc like this:
From lockRequest(unsigned long lockTimeout_ms) remove
if (!lockTimeout_ms)
if (!connectToAsynPort()) return false;
And modify lockHandler():
void AsynDriverInterface::
lockHandler()
int connected;
debug("AsynDriverInterface::lockHandler(%s)\n",
clientName());
pasynManager->blockProcessCallback(pasynUser, false);
connected = connectToAsynPort();
lockCallback(connected ? StreamIoSuccess : StreamIoFault);
Does this work?
Dirk
Mark Rivers wrote:
Benjamin,
I'd be interested to know if this problem is restricted to streamDevice,
or if it also happens if you use, for example, an asynRecord to talk to
the device. Is it possible to test that, loading just an asyn record to
communicate with your device, and see if it re-connects after a power
cycle?
I have seen some behavior I don't understand with asyn autoconnect on IP
devices, and I've been meaning to work with Eric to track it down.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Benjamin Franksen
Sent: Monday, January 28, 2008 4:43 AM
To: [email protected]
Subject: asyn/stream reconnect problems
Strange things happen here:
When I turn off and on again a GPIB gateway (E5810A)
controlled via soft
IOC, asyn, and streamDevice, sometimes the connection is not
re-established. However, it reconnects as soon as I enable or
disable asyn
debug messages a la
asynSetTraceMask L3 20 0x0000
Here is a transcript that illustrates what happens:
epics> asynSetTraceMask L3 20 0x0010
[now I turn power off and on again]
epics> 2008/01/28 11:11:29.645 L3 vxi11 clientCall errno
Success clnt_stat 5
L3 vxiWriteAddressed _? RPC error : RPC: Timed out
2008/01/28 11:11:29.645 L3 callback
2008/01/28 11:11:29.645 L3 addr 20 queueRequest priority 0
not lockHolder
2008/01/28 11:11:29.645 L3 schedule queueRequest timeout
2008/01/28 11:11:29.645 L3 20 vxiWrite numchars 17
2008/01/28 11:11:29.857 L3 asynManager:queueTimeoutCallback
2008/01/28 11:11:29.937 L3 asynManager:queueTimeoutCallback
2008/01/28 11:11:29.937 L3 addr 20 queueRequest priority 0
not lockHolder
2008/01/28 11:11:29.937 L3 schedule queueRequest timeout
2008/01/28 11:11:29.992 L3 addr 20 queueRequest priority 0
not lockHolder
2008/01/28 11:11:29.992 L3 schedule queueRequest timeout
2008/01/28 11:11:39.645 PAHRP:NRVD:rdPow(2): asynError in
write: L3 RPC
failed
2008/01/28 11:11:39.645 PAHRP:NRVD:cmdGtl queueRequest
2008/01/28 11:11:39.645 L3 addr 20 queueRequest priority 0
not lockHolder
2008/01/28 11:11:39.645 L3 schedule queueRequest timeout
2008/01/28 11:11:39.645 L3 callback
not lockHolder
2008/01/28 11:11:39.645 L3 20 vxiWrite numchars 17
2008/01/28 11:11:39.993 L3 asynManager:queueTimeoutCallback
2008/01/28 11:11:40.032 L3 addr 20 queueRequest priority 0
not lockHolder
2008/01/28 11:11:40.032 L3 schedule queueRequest timeout
2008/01/28 11:11:45.674 L3 vxiDestroyDevLink RPC error : RPC:
Unable to
send;
errno = Broken pipe
2008/01/28 11:11:45.674 L3 vxiDisconnectPort : RPC: Unable to
send; errno =
Broken pipe
2008/01/28 11:11:47.681 L3 vxiDestroyDevLink RPC error : RPC:
Unable to
send;
errno = Broken pipe
L3 port not connected
2008/01/28 11:11:47.681 L3 asynGpib:pollAddr srqEnable
2008/01/28 11:11:47.681 PAHRP:NRVD:rdPow(1): asynError in
write: L3 RPC
failed
2008/01/28 11:11:47.682 L3 addr 20 queueRequest priority 0
not lockHolder
2008/01/28 11:11:47.682 L3 schedule queueRequest timeout
2008/01/28 11:11:50.033 L3 asynManager:queueTimeoutCallback
2008/01/28 11:11:50.033 L3 addr 20 queueRequest priority 0
not lockHolder
2008/01/28 11:11:50.033 L3 schedule queueRequest timeout
2008/01/28 11:11:50.038 gpib0 vxiCreateDeviceLink abort
channel TCP port
changed from 1002 to 1005
2008/01/28 11:11:50.096 L3 addr 20 queueRequest priority 0
not lockHolder
2008/01/28 11:11:50.096 L3 schedule queueRequest timeout
2008/01/28 11:11:57.681 L3 asynManager:queueTimeoutCallback
2008/01/28 11:12:00.033 L3 asynManager:queueTimeoutCallback
[The last few lines repeat endlessly; device stays
INVALID/TIMEOUT; now I
do:]
2008/01/28 11:17:12.557 L3 addr 20 queueRequest priority 3
not lockHolder
2008/01/28 11:17:12.557 asynManager connect queueCallback port:L3
2008/01/28 11:17:12.557 L3 addr 20 vxiConnect
epics> 2008/01/28 11:17:12.559 gpib0,20 vxiCreateDeviceLink
abort channel
TCP
port changed from 1002 to 1005
And suddenly connection is established again.
Is this a known problem? Is there a fix?
My setup: linux-x86, epicsBase3-14-8-2, asyn4-8, streamDevice2-2
Cheers
Ben
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- Re: asyn/stream reconnect problems Benjamin Franksen
- RE: asyn/stream reconnect problems Mark Rivers
<2008>
2025
2026
<2008>
2025
2026
