On Tuesday 29 January 2008 11:20, Dirk Zimoch wrote:
> Hi Ben,
> Please try to modify AsynDriverInterface.cc like this:
> From lockRequest(unsigned long lockTimeout_ms) remove
> if (!lockTimeout_ms)
> if (!connectToAsynPort()) return false;
> And modify lockHandler():
> void AsynDriverInterface::
> lockHandler()
> int connected;
> debug("AsynDriverInterface::lockHandler(%s)\n",
> clientName());
> pasynManager->blockProcessCallback(pasynUser, false);
> connected = connectToAsynPort();
> lockCallback(connected ? StreamIoSuccess : StreamIoFault);
> Does this work?
No, the behaviour is the same as before, which I found is in fact quite
predictable: The first time the E5810 reboots, the IOC will re-connect
fine. The second time, it won't. Also, I found that when it doesn't
re-connect, the last message is
2008/01/29 12:57:54.509 gpib0 vxiCreateDeviceLink abort channel TCP port
changed from 1002 to 1005
while in case it /does/ re-connect, this message is followed by a similar
one:
2008/01/29 12:57:22.225 gpib0 vxiCreateDeviceLink abort channel TCP port
2008/01/29 12:57:22.231 gpib0,20 vxiCreateDeviceLink abort channel TCP port
Also, in those cases where I can cause re-connect to happen by issuing e.g.
asynSetTraceMask L3 20 0x0000
I get the 'missing' second message immediately afterwards:
epics> asynSetTraceMask ${GPIB_LINK} ${GPIB_ADDR} 0x0000
epics> 2008/01/29 13:35:59.379 gpib0,20 vxiCreateDeviceLink abort channel
TCP port changed from 986 to 1005
Maybe this could be a hint to what's going wrong?
I said "in those cases where I can cause re-connect to happen..." because
when today I checked the IOC in the morning, there was /no/ way I could
convince the IOC to re-connect. I had to re-start it. OTOH, I cannot
completely rule out the possibility that someone (or something) restarted
the IOC while the E5810 was off, which would, I think, mean that
asyn/vxi-11 never created a connection in the first place.
Anyway, we are now focussing on how to restart soft IOCs from the iocsh, so
that we have at least a fallback inplace.
Cheers
Ben
- Re: asyn/stream reconnect problems Eric Norum
- RE: asyn/stream reconnect problems Mark Rivers
- Re: asyn/stream reconnect problems Dirk Zimoch
Re: asyn/stream reconnect problems Benjamin Franksen
<2008>
2025
2026
<2008>
2025
2026
