1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asyn/stream reconnect problems
To: [email protected]
Date: Tue, 29 Jan 2008 15:20:50 +0100
On Monday 28 January 2008 18:38, Mark Rivers wrote:
> I'd be interested to know if this problem is restricted to streamDevice,
> or if it also happens if you use, for example, an asynRecord to talk to
> the device.  Is it possible to test that, loading just an asyn record to
> communicate with your device, and see if it re-connects after a power
> cycle?
The problem is that the device (the one controlled via the E5810) is one of
those complicated beasts, where we have to wait for an SRQ and only then
ask it for the measurement, otherwise we get the old value. I am not sure I
could reproduce even remotely similiar behaviour with a asynRecord.
Anyway, my testing time at the machine is now over :(( I can try to
reproduce the problem on my desk, but this will take some days...
Cheers
Ben
RE: asyn/stream reconnect problems Mark Rivers
Prev: Re: asyn/stream reconnect problems Benjamin Franksen
Next: Re: asyn/stream reconnect problems Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asyn/stream reconnect problems Eric Norum
Next: Re: asyn/stream reconnect problems Allison, Stephanie
