As I mentioned earlier have a look at comedi.org for PCI devices.
On there website you will find a list of supported hardware.
I use mostly measurement computing equipment, but many more vendors are
supported.
For example, I use the DDA0816 which has 8 AO and 48 configurable TTL
outputs. Works great but pricey if you just want to use the TTL outputs.
I also heard that there is a comedi interface for asyn.
I never used it, but you may want to have a look at it
https://sourceforge.net/projects/epicscomedi/
Good luck,
E
On Fri, 2008-02-22 at 13:40 -0600, Jiro Fujita wrote:
> Thanks, Emmanuel.
> Running EPICS on Linux is not the problem. I have been doing that for
> a few years.
> We have a relatively large number (~ 100) of FEE cards that only takes
> on and off via TTL. All what it does is turn on or off the FEE card.
> So, using the parallel port probably will not work.
> I guess I am looking for if anybody is controlling any devices via TTL
> using a PCI card in Linux using EPICS. If so, I would like to know
> which TTL interface card and exactly how you are doing that.
- TTL output with soft IOC on Linux Jiro Fujita
- Re: TTL output with soft IOC on Linux Emmanuel Mayssat
- Re: TTL output with soft IOC on Linux Jiro Fujita
Re: TTL output with soft IOC on Linux Steve Lewis
<2008>
2025
2026
<2008>
2025
2026
