1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: TTL output with soft IOC on Linux
To: <[email protected]>
Date: Sun, 24 Feb 2008 20:10:15 -0600
Might also look into some of the cards from Measurement Computing.  I'm
using a 96 bit card from them that one of my coworkers spent about a day
and wrote a basic driver for.  Seems pretty simple, and there are cards
with 24,48,and 96 bits of input and output.  Plugs directly into SSR
relay racks, also.
David Dudley
City of Corpus Christi
>>> Robert Horrox <[email protected]> 2/22/2008 6:04 PM >>>
Jiro,
You may want to look into the Acromag ES2113 discrete I/O device.  It
supports ModTCP and I have been able to get it working with the Modbus
driver written by Mark Rivers for Asyn.  You would need to provide 5v
pull
ups for the ES2113 and I'm unsure of your timing constraints so I can't
be sure if it would work for you.
I do have some performance specs that I made when I was working
with the ES2113 this summer if you are interested.
Have a good day!
Robert Horrox(KE7JAX)
Electrical Engineering Undergrad ([email protected])
President Amateur Radio Club at the University of Washington
On Wed, 20 Feb 2008, Jiro Fujita wrote:
> Has anybody worked with a simple TTL devices (on and off only) with
> soft IOC running on Linux??
> We have a number of FEE for one of the sub-systems for STAR detector
> at Brookhaven National Lab that we currently control via  EPICS 3.12
> with VME that we would like to move to soft IOC on Linux if all
> possible.
> I appreciate any informations/suggestions on this.
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
RE: TTL output with soft IOC on Linux Mark Rivers
TTL output with soft IOC on Linux Jiro Fujita
Re: TTL output with soft IOC on Linux Robert Horrox
Prev: Minor VLinac compilation problem on OS X 10.5? Bertrand H.J. Biritz
Next: RE: Problem with soft motor record Shepherd, EL (Emma)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: TTL output with soft IOC on Linux Robert Horrox
Next: RE: TTL output with soft IOC on Linux Mark Rivers
