1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: TTL output with soft IOC on Linux
To: "David Dudley" <[email protected]>, <[email protected]>
Date: Wed, 27 Feb 2008 13:21:50 -0600
There are also very inexpensive USB devices:
http://www.l-trondirect.com/usb-4751l.html
USB-4751L
USB-4751L is a 24-bit digital I/O module for the USB bus. Its 24 bits
are divided into 6/3 8-bit I/O ports and users can configure each port
as input or output via software. USB-4751L also provides one event
counter and three 16-bit timers, which can be cascaded to become a
32-bit timer.
Compatible with USB 1.1/2.0
Portable
Bus-powered
24 TTL digital I/O lines
Emulates mode 0 of 8255 PPI
Buffered circuits for higher driving capacity than 8255
Interrupt handling
Timer/Counter interrupt capability
Supports both dry and wet contact
50-pin Opto-22 compatible box header
Suitable for DIN-rail mounting
Lockable USB cable for rigid connection
A soft IOC using libusb on Linux should be pretty easy.
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of David Dudley
> Sent: Sunday, February 24, 2008 8:10 PM
> To: [email protected]
> Subject: Re: TTL output with soft IOC on Linux
> Might also look into some of the cards from Measurement
> Computing.  I'm
> using a 96 bit card from them that one of my coworkers spent
> about a day
> and wrote a basic driver for.  Seems pretty simple, and there
> are cards
> with 24,48,and 96 bits of input and output.  Plugs directly into SSR
> relay racks, also.
> David Dudley
> City of Corpus Christi
> >>> Robert Horrox <[email protected]> 2/22/2008 6:04 PM >>>
> Jiro,
> You may want to look into the Acromag ES2113 discrete I/O device.  It
> supports ModTCP and I have been able to get it working with the Modbus
> driver written by Mark Rivers for Asyn.  You would need to provide 5v
> pull
> ups for the ES2113 and I'm unsure of your timing constraints
> so I can't
> be sure if it would work for you.
> I do have some performance specs that I made when I was working
> with the ES2113 this summer if you are interested.
> Have a good day!
> Robert Horrox(KE7JAX)
> Electrical Engineering Undergrad ([email protected])
> President Amateur Radio Club at the University of Washington
> On Wed, 20 Feb 2008, Jiro Fujita wrote:
> > Has anybody worked with a simple TTL devices (on and off only) with
> > soft IOC running on Linux??
> > We have a number of FEE for one of the sub-systems for STAR detector
> > at Brookhaven National Lab that we currently control via  EPICS 3.12
> > with VME that we would like to move to soft IOC on Linux if all
> > possible.
> > I appreciate any informations/suggestions on this.
Re: TTL output with soft IOC on Linux David Dudley
Prev: RE: Multiple target os-class application build Mark Rivers
Next: Re: Are EDM screens forwards compatible from version 1-10 to 1-11? John Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: TTL output with soft IOC on Linux David Dudley
Next: XDMCP Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO]
